picking up some gear from our friendly resident supermod tomorrow, will be fitting most of it as soon as i get my grubby hands on it. andrew's dropping by with my pipework on saturday, and then hopefully, if the planets align or whatever, on sunday it will move under its own power for the first time in 10 weeks.
ey Dave, have you received your boost controller yet?
i seen you bought one (from the same vendor) last week as well. i'm still waiting for mine - its been a bloody week... regular post from melbourne should take 2-3 working days max...
no, not yet. im giving him til friday, then ill be shooting off a couple messages. doesnt bother me much now though, getting an ebc tomorrow for $100.
cheers carl! might look into that. do something productive with my boredom. lol.
Edited by scandyflick
in prep for track day.........
anyone got advice for attaching bumper car bumpers to a gtr?
possibly go the cheaper option of duct taping cushions to front and especially the rear which i no scandy likes to gun for
Edited by Inline 6
sure thing steve, might be a week or two (assuming i get it within the next week) as i wont be able to afford to have the ebc tuned for a little bit.
That's cool, I'm in no hurry so whenever you're ready to part with it let me know.
Lol cara the Blow off valve its self has nothing to do with the type of turbo you are running so Just use a R34 BOV or whatever you can get your hands on, Maybe get an aftermarket one that lets it go to the atmosphere so you dont have to worry about modding your air intake to suit the plumb back factory style.
nah id rather go stock bov.
Cara, if you haven't done so already, keep in mind the Neo motors have a longer throttle body, so the intake piping to which the BOV is attached to is shorter than your average 33. Therefore the 33 intake piping wil not suit your Neo. Need a Neo DET pipe.
:P
oh ok....how easy is it gonna be to get one of these tho?
in the life of dan......
friggen house company has taken 4.5 months to finally get the paperwork to the builders ready to start building, not impressed. apparently they were also thinking of sending me a added bill for it taking so long when ive only taken 24hrs with each bit of paperwork and nagged them reguarly to get off there ass.
i needed to vent :P
Guest
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
