Mark, I nabbed it for $450, absolute bargain!
Kye, it's the JJR one, here's the link
Meant to reply to your SMS today, sorry, been busy. Unfortunately I can't make it, the missus committed us to her friends 22nd that night, dress up so I don't really want to go :P I've got to organise a time to get the y-pipe of you if you don't mind, very keen on getting that sorted
Luke, thats hot. :P
My old man picked up a 1994 Mitsubishi Delica Spacegear today and I got to drive it home, 2.8L turbo diesel 4WD... it came with a Nardi Torino steering wheel! I'd nab the steering wheel if I had a car to put it into lol the R33 requires airbag and the daily honda has the cruise control switches which I dont want to lose.
I was going to do the high boost mod on my car today but unfortunately got stuck at my mothers house all afternoon!!!! :P
skip it and put a bc in mate. i did it over the weekend, set mine to approx 12psi tonight. effing fantastic i tell ya!
turbos almost off again. rotated it from the exhaust wheel by hand while it was still on the engine, made a nice little grinding noise. sigh.
anyone know anyone who has a t28bb lying around?
and what are you trying to say huh? huh? huh? :P
never u mind hehe
heslo: envious of the airbox.......always loved the ARC stuff....except the price
luke_enr34: have you got any cables coming thru any grommets in the firewall...............could be water coming from road spray (in the engine bay) working its way thru. mate of mine had same issue, he thought his windscreen was shagged in his patrol (plus the next 2 they installed). turned out it was his cabling for the spotties that was tracking the water in via the grommet
The things i know :P
Got my dash out today. Now to remove all the air-con components and just have the rear demister and a fan for the front window. Gonna be a shit load of space behind the dash now. Thinking of making a cf panel with 2 switches on it.
I have stock ecu, turbo ect ect ect. Little worried about detonation going for more than 7 psi. Did you bypass the factory solenoid altogether?
Yep, bypass it. You can still wind in decent boost with the stock ECU so long as your EBC is set up correctly... probably better off going that route to be honest. Then when you want/can afford go for a full fledged aftermarket ECU and get a tune, then you'll really see some gains!
turbos off. comp cover had half blown off. pulled the cover off completely, theres a couple marks on it, and theres some scraping on the blades, so ill be looking into some options tomorrow.
certainly did Steve
yeah the stock ecu is definitely a setback with boost - rich & retard really sucks. power wasn't being distributed nicely through the rev range - anywhere from 3500 - 6000 rpm was very flat, but as soon as you passed 6000, this big hit of power would chuck you back in your seat.
however -
when i added my fmic, i took the car for a drive around the block with the front bar and reo off -it was boosting almost 1 bar! and this was with the standard solenoid, and standard ecu - it flew! but as soon as i put the reo and front bar back on, boost dropped back to 9psi
Im runing a remapped ecu now, good bang for buck, and its roadworthy :P
How much is safe? I might have to do some homework on ebc's... :P
certainly did Steve
however -
The only thing that annoys me really is the fact it hits the boost limit (5 psi I think...?) under 3000 RPM since the AM dump/front/cat and 3-3.5" catback has gone on. Would like just a little extra between 2800(approx)-5000 RPM.
Nice Luke...stretched rubber on the rears? :)
Guest
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
