not that i have tickets, its im not a tax accountant. some might say not good enough to be doing peoples tax's
note andrews high tax returns are a direct result of a incorrect entry on his tax file number declaration form, resulting in any incomptent fool able to give him a satisfactory result :P
Edited by Inline 6
note andrews high tax returns are a direct result of a incorrect entry on his tax file number declaration form, resulting in any incomptent fool able to give him a satisfactory result :D
And you say you're not good enough to do peoples tax :D
You're too modest Dan ;)
:P
So whats your number i need my tax done ;)
I'm happy the Skylines (and imports in general) were not shown in bad light. And I'm happy SAU:SA wasn't mentioned at all ... no news is good news.
As for SAU:SA's status in this. Neil Hastie contacted me earlier about this story. Although it is not mentioned in the papers, Neil (and SAPOL) is aware that a majority of car clubs (SAU:SA included) are predominantly car enthusiasts. My hat is off to Neil for protecting the real enthusiasts.
I can't and won't say much at this time. But I will be meeting with Neil again in the near future. Can we please be positive about this, and not give the media any more untruths and rubbish to go on about. Let the Commo and Falcon hoons bury themselves.
i read the article just before (was working all day yesterday) and im glad they didnt mention SAU:SA, so yes no news is good news for sure.
sadly enough the media makes up there own untruths and rubbish. - i mean i have been called a hoon a few times, and i ahve just turned around to the person and gone, excuse me wtf!!!!! so rude when someone you dont know turns around and says so thats your hoon car? and then later on starts telling me about how he has done over 200km/h in a 80 zone just out of tailem bend - yeah good on ya buddy, your my hero for sure.
never u mind hehe
ORLY ????
Guest
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
