lol for a second there i thought you said "ill buy you a six pack of your troubles" :)Never knew sadness could be bottled.
Sure it can, it's mixed with a healthy dose of happiness in every bottle with an alcohol content :)
Sometimes the happiness is the dominant emotion, sometimes the sadness shines through, it's part of the fun of drinking :down:
Also, YAY for Chad :(;) I'm the blue sil, second car in frame on that vid :D the cam didn't seem to capture the savageness of the Bee*R very well though :D
Edited by AndrewJZX100
I just hills tested my new Yellow Jacket coilpacks that I fitted late this afternoon... my god the car drives so smooth its awesome - I cant remember the last time the car driven this well! :)
hey Vu good work hey.
makes the car a pleasure to drive eh
still falling all over back in love with my stag, still, since the 240rwkw tune.
got injectors ready to drop in and retune, just no money tho.
as it is, 2ft flames outa the pipe probably isnt a good thing :down::)
oh yeah, rev limiter - mines been bumped UP by 750rpm I think, from 6500 to 7250
yeah i remember when i chucked in the splitfires....noticed a nice difference in how smooth the car was running
they will always feel better than old, genuine parts. if anyone was silly enough to buy brand new genuines, im sure they would provide the same return.
this is the first car ive owned that ive paid more than 6 months rego on at a time...........its a lot in one hit but at least you dont have to worry about it for 12 months i spose.
for those that may have seen the status update, i might be onto something of a plate idea (contrary to dave's RCHAROUND idea)
oh damo, how'd ya get on about those lights?
Rego went up in price... very nice. 3 months is now $196 / 12 months is $735....
Well at least they are doing something with it, I drove down the freeway on satdy where the upgrade had been completed recently and it was pretty nice.
Loby road got a bit of work in the first half of the year also, along with a few other troublesome patches of macadam around the hills, so at least they're using SOME of the cash for it's intended purpose.
Still gonna sting a bit when rego for the sil is due in about a month :)
Guest
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
