could certainly give u feedback if u like :) email me ur schematics dude
-D
haha need someone handy will a solderin iron and wood / plastic work? :)
I Recomend VDO gauges too, they make a series of gagues in different designs an layouts for pritty much anything.
Anyone know how i would go to wire up 2 switches. One for the rear demister and one for the front window fan?
Just test the loom while turning one at a time off and on again until you find the wires you want. ether that for get a schematic and look through that.
Edited by Jack88
I can highly recommend jack for solder jockey work ;D (after all Im shit at it and made him do it all)
My dick is still bigger than his tho yall
-D
as above i cant pm for some reason cara, tried to earlier for you too and couldnt.
so ill put it here, Kye Hansen 230-250rwkw? im only guessing haha
ok thanks for that dude :)
i might be getting Saber gauges depending on the price :)
Guest
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
