I'm not gay, the guy who feels me is
and guys that wear man scarves.
did glenda end up getting the rotor? if he didnt i know of an s4/5 with a fair bit of awesome shit going for 10k.
Nope, but the XR4 has left, finally! He's now buying Josh's Silvia, and Josh is buying a 33 by the looks of it, or a DC2 Integra
never fear Josh is here
dave & luke, running with the 33 idea at the moment......cant find shit for a reasonable price except for the blue one, this is the kind of car/look i want (minus the auto)
http://www.carsales.com.au/all-cars/privat...me&__Nne=15
last night a white 31 was into a pole at the start of the express way, looks like they tried to take the entry to the express way too quickly in the wet and went head first into one of the light poles.
Hope it was no one from on here!!!
The boxes aren't THAT expensive, it's the parts you'll need while doing the conversion. Give smooth a buzz and see what they'll charge so you've got a ballpark figure before you even bother. Boy Glenn will love this, a 33 AND auto :)
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
