ah well, will just push the 'scene' more 'underground', which is good and bad....ah well
That's what everyone is saying, I beleive it too. :P Ah well, won't stop our little runs regardless, probably the best way to have them too, small, tight-knit, and trusted friends
Massive numbers through the hills is aids anyway.
Very true! PM me you're number, I'll send you a message next time we hold a little cruise of our own.
Josh, found these... what you reckon, good present for Glenn's birthday?
massive lol at this damo.....i know a few of the people that have there cars in the cars of the month thing haha. i wouldnt give them an award for making it out the drive way, just about all of them on that page are a stock as a rock como with mags on it. nothing i dont already see hundreds of every day lol.
You might have been at Sinergy when i got my 33 too Wayne? Had those Enkei Bortex fitted when i got it.
Rocco is a total champ, always looks after me and Rob has known me since i was about 3 or 4. Rob's brother Eddie is my brothers mate.
Post up a photo of the car man, I dare say I did all the compliance work on it :P
Landed just before they moved to Medindie. Series II manual, Rocco had KYB Buzz Specs and the Enkei Bortex's fitted before i picked it up. Now running Impul NS-GT's 18x8.5's and JIC's
Edited by Jamesrb25
River on the other hand...
Don't even get me started on river, that hecktik fpos LOL...
I sold more cars then him and I was a mechanic. Ohwell hes gone now and I don't work there anymore.
James, i don't recall your car mate, I started working there March 08' so probably sold before I started?
Lads, I am off to work.. I know... its freezing... Not looking forward to it trust me.
Speak to you all tomorrow or something lol.
lol, i love for sale ads.
This is a well cared for and looked after car and has NEVER been thrashed or driven hard.
mod list...
*17psi Boost dyno tuned for daily driving
*Walbro 500hp in tank Fuel Pump
yeah, 17psi is pretty normal i spose.
and lol, s2 with stock turbo, external gate and pfc. :P
Edited by scandyflick
lol you could try starting a thread about how youve lost your license and it was unfair because you were going 150 instead of 140 and can i take the cop to court about this:P works well for others on school holidays here
Yeah I think my turbo is on its way out, Ive noticed more and more blue/white smoke after heavy acceleration - never used to do it :P Ive been told its the seals....
Happy Birthday James ;) (Jamesrb25)
Edited by dark.sky
Guest
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
