i changed my spark plugs last night. wow that was some serious fun! haha no seriously it was!!
anyway on saturday night i had a feeling to check my 1 cylinder plug dont know why just did. and im glad i did the electrode was melted away! so yesterday i changed them (im so proud of myself lol) to discover that not only cylinder one was like that but also cylinder three. so im guessing that just means that those two cylinders are creating more heat than the others cause they were melted at all.
my god its made a difference though she is heaps smoother now and this morning was the true test. normally when the cold choke is on and you accelerate, it feels like something is holding the car back from getting speed, but then it will allow the car to speed up (its weird) but this morning it didnt happen! i originally brought it down to the Power FC cause the spark plugs that were in there had only been put in just before Extreme Horsepower last year, so i didnt even think that it could have been the sparkies at all.
i know its probably not the best pic, but the sparkies on the left was taken out of cylinder three and the one on the right from cylinder five. just to show the difference.
Could it be that it was tunned for no2 and it doesnt run it all the time
With N20 you shouldn't be melting the strap.
Cara. Do you run a wet or dry system?
Also steer clear of platinum plugs with n20. Use good old coppers or iridium.
hey guys
ive spoken to my tuner and i have also come up with some ideas on why the sparkies have melted.
my tuner has said that she could be running to lean on the top end, which means if i have to much open throttle i could do damage to the engine. im gonna try and book her in this week. im really worried about it cause i dont want to have damaged the pistons let alone blow my engine :( its a sickening thought that there could be damage already done because i dont know how long the spark plugs have been like that.
the ideas ive come up with why they have melted is the nos (plugs just couldnt handle it), extreme detonation (which was happening), the mixtures isnt right at the moment, blockage somewhere, i changed the o2 sensor so im thinking that might be a reason too, i havent really done much to the engine of recent other than the rocker cover gaskets and the o2 sensor. before that the power fc, gtt injectors and nos was put in
there is so many possibilities on why this could have happened. im not pointing the finger at my tuner for doing a crap job cause i know he knows what he is doing.
and Cubes its a wet system.
mind you guys her last tune was in december (maybe over due big time)
it hasnt been detonating since the new O2 sensor was put in
ive heard my car ping before, but that was just a matter of getting the timing put back to fix it
ive got her booked in for sat morning so ill just drive her nicely until then.
good luck
Im waiting for my chip to be mapped, and the chip adapter to arrive from japan
once thats all sorted and a tune/map is written on the chip, I'll get my safc/sitc adjusted for hopefully the final time.
with the remap Im hoping for 205awkw / 215rwkw
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
