anyone have some decent res pictures of skylines from car shows or private photo shoots that they dont mind me using for promotional material? Can you link to me your photo hosting site or email them to me?
Can anyone give me some advice? I have a Haltech E11v2 that i will be installing in my car soon, should i use the 3 bar map sensor that came with it, or go buy a z32 afm? I am aiming for 250rwkw+. Which one would be better for a stable tune, less likely to play up, and doesn't need to keep getting re-tuned.
From what I understand...
A Map sensor will need to be retuned everytime you do something different to the car from what I understand but wont stuff up,
Where as a afm will sort of 'adapt' to minor mods but can stuff up.
haltech ecu's are pretty damn hardcore. they shit over powerfc's, unfortunately theyre usually 3 times the price most of the time
map sensor wont be as affected by resin coming off a reusable air filter. my maf sensors have cooked a couple times after getting the medium cleaned after getting some of the oil on the sensor and then the sensor heats up and stops reporting the right flow. they can be cleaned, but i'd be going for the map sensor (I think thats what the powerfc D-jetro's are too, someone correct me if Im wrong)
-D
Damo/Allllllll of SAU, longtime no talk :D .
I have a crapload of high res skyline pics from various shows and many of jacks 33, and just heaps of skyline photos in general. What sort of pics are ya after? :D
Bosch 044 flow's 30% more then GTR iirc?
probably a better option depending on what power you want
true but a nismo fuel pump which flows just as well as the 044 can be mounted in the stock cradle without mods
the 044 is around $280 or so and the nismo is $450 odd, but if you're like me and have to pay for labour then its almost worth springing for the nismo
the 044 is an external fuel pump, im not sure how well they go with being submerged but i know people have done it
the 040 is internal but doesnt flow anywhere as near as much - its a good replacement for the oem pump but if ur running heaps of boost or aftermarket injectors you'd probably be best off just getting nismo - i plan to get nismo when it comes time to replace it. so far my stocker is still going nice
-D
-D
Ive got a GTR fuel pump in my car which was flowing 223rwkw but was leaning out which i think was due to injectors restricting flow but the stock GTR pump is fairly good :D
Guest
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
    • I have a wheel cleaner pokie thing which is a glorified microfibre rag on a stick, and there is not sufficient clearance between the caliper and the barrel to clean that section. I just roll the car forward 500mm and have another shot at each wheel.
    • The "rag on a stick" is a easy way to fit in between the wheel spokes into all of the barrel Albeit I do have 10 spokes on the MX5 which limits the access to actually jam my hand in to clean the barrel, but it was also makes much easier to clean the 5 spokes on the Dunnydoore with it as well, as you don't have to worry theΒ  caliper getting in the way if you have at least about 15mm space between the caliper and barrel This of course depends if you actually have the clearance between the barrel and caliper, and the amount of OCD you have to get the barrels as clean and shiny as the face of the wheel The thing is bendy as well so you can actually shape it to conform to the inner lip of the barrel Β
    • FWIW, as well as a basic immobiliser/remote unlock (all basic units give you those 2 things), I would also install a 4g tracker in any car I cared about. Just hide it anywhere that won't be found in a rushed look and preferably get something with a built in battery backup so it stays online for a while when the battery is removed or flat While its not a car, when our car trailer was stolen in that den of crime Sydney about a decade ago, the cops were watching from the bloke's neighbour's lawn within about 2 hours until he started swapping the plates and putting up the gumtree ad.Β Β  Obviously it is still not undefeatable (eg parking it up for a few days somewhere without sky sight) but it greatly improves your chances of getting it back quickly and with less damage
    • Instead of magic keyphrases I wonder if something can be done with auto complete. Similar to how user names are handled already. When you type '@' and follow with letters, it'll search across all usernames. It might work to have the same for forum topics. Some key to trigger it and then text search across all thread names and it'll insert the name and URL when pressing enter.
Γ—
Γ—
