tomei all the way! no complaints with my fuel pump so far. its internal
tomei are indeed another notch up from the nismo/044 series. great for track but overkill for street cars (unless yr doing 400kw+ lols)
fyi DI, the stock gtr pump should be able to do 260-280 safely, possibly more if u have an FPR (so I've been told at least, i know my car has done 260 kw on unsafe boost with stock injectors, pump and fpr)
-D
If you have the money, go a nismo
I have a Nismo.....
It's what i named my rabbit ahaha. He used to fit in the drink holder of jacks 33....not so much anymore :D
Edited by fullyhyperlite
hrm i was about to post that nismo fpr's are a tad cheaper than the tomeis but i checked nengun
http://www.nengun.com/nismo/fuel-pump-skyline $416
vs
http://www.nengun.com/tomei/fuel-pump-nissan-skyline-r32-gtr $398
not a great deal but maybe I'll grab the tomei rather than the nismo :D provided it bolts up the same!
-D
I used to have two rabbits. One of them I called 'Stew'. Its a really nice name dont ya think?
the other one I called Starsky
cos when it got dark I used to put him in hutch
-D
very original.
but also sounds completely fabricated. rabbit stew ay. can't say i'd eat a rabbit.
only pet we've had who's cousins iv consumed, were wallabies, and i can't say no to eating kangaroo. ahh well.
very original.
a decent rabbit stew is pretty good. you'd want rabbit (aka hare/coney) mind you, bunnies are too small
Rabbit Stew Yo
really good winter food that
had a great kangaroo steak the other day from the butcher.... i overcooked the shite out of it, was wicked. i used to love making stirfry kangaroo steak n veg in black bean when i was living by myself heh. dont even like beef steak or lamb chops but kangaroo tastes wild. stinks like rotting flesh when its uncooked tho, thats the only downside. you defrost a kangaroo steak and ur mates ask u if you've killed a prostitute and buried her under the kitchen. not cool eh
-D
Damo/Allllllll of SAU, longtime no talk :D .
I have a crapload of high res skyline pics from various shows and many of jacks 33, and just heaps of skyline photos in general. What sort of pics are ya after? ;)
Hey Chaz, im after club group shots, and maybe a couple of your fave skyline shots. Have you hosted any online?
Quite awhile ago, my cousins had the bunnies that are meat kind, the ones bred so you can eat them. Well, long story short, since my cousins are female, they got too attached and couldn't bare to have them killed and then eat them.
Edited by Aberax
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
