What the hell is with the non iced coffee drinkers here?? its very unAustralian!
nicely said Penny. god damn un australian people
i dont enjoy any type of coffee.
you will die a horrible horrible death.
You wouldn't want to be around me in the morning if I skipped my coffee..... :thumbsup:
+1
unaustralian people drive DE's...
im now the proud owner of a set of blitz 550cc injectors...
... scratch that. im getting the nismo 740's instead...
Edited by scandyflick
i dont really mind spending the coin. only pisses me off a little. and ill get most of it back when i sell it. the only thing that bugs me is the time off the road.
atmo cars are boring as batshit. well, the affordable ones are. ferraris are quite enjoyable.
Complete set of Gates belts going on tonight (set of 4) ... fun times ahead removing the radiator and crank pulley :thumbsup:
Aren't cars awesome? :thumbsup:
Edited by RubyRS4
haha, i just talked krish into buying a turbo.
Which one?
I took that dump pipe to my local exhaust place, he made a gasket up then and there for me for $10, love local businesses.
Edited by Aberax
hypergear atr28-g3. i should totally get a commission for that shit.
I know and pretty damn cheap as well was so happy with it.
Now just waiting for an email and see what happens from there on....gota get a few custom bits made up and a awesome tune and walla....we are all good to go....hopefully can have it all done by the dyno day ohh yeah
cheers Dave
Guest
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
