Well i had a blast from the past today, page 6 of the Sunday Mail. My last ex, no mention of the hell i had to put up with on a daily basis for 3 yrs! But at least she is getting help finally!
yeah sorry to hear about your Mum Luke! Hope she is better very soon .... thank her a bunch for the Crows tickets today - they were AWESOME!!!!!!!!!!!!!!!!!!!!!!!! I will drop back the tickets tomorrow night with any sort of luck - I will ring u b4 I come.
go you Crows :angry:
Nightcrawler edited out as per Talbo's request
I knew if Rann got in we'd be going backwards to the 1960s. But I wouldn't go giving up just yet. Rann's BS laws will only go as far as those enforcing them ... and anyone with half a brain can see the flaws in his 'ultimate plan'. Legit car clubs across Adelaide are working with SAPOL for that good report card.
not questioning it, just you have been talking about super chargers and turbo's lately.... thought you might have chucked something on there. At the end of the day it's horses for courses.... how fast can one go with all the nazi government shit...?
Everyone's projects are limited by their income and personal lives. I think a few people (not pointing to you Talbo) need to back off Cara for a bit. Cara has gotten alot of conflicting info on her project which has been out of her control. We've all had projects that never go to plan.
Thanks for all the warm wishes guys, just came back from the hospital and seems everything is ok, thankfully!
Andrew, glad you enjoyed the tickets mate, definately a good game to be at and a great result for the good guys! Don't thank my mum (she's one of those retard feral supporters), the tickets belong to the missus' parents, I'll pass on your thanks
Sigh. My headunit partially packed up a while ago, on the 30th of May contacted them about it. Took me a while to convince them it actually needs to be looked at, so anyway I sent it off via registered post, I have been getting in contact roughly every 2 weeks and I pretty much get "were doing more testing" each time. The fault is not intermittent, so I dont know what the hold up is. :P
I'm not 100% sure what I was on about last night (nor were those on fb)... but for the record I'm not really worried about the new laws anyway :) Can a moderator delete that jibberish pls?
I know you didn't direct that at me, but again for the record I wasn't giving her a hard time and I don't think I'm in a position to give anyone shite about their car..... :P
@Damo - I'll ask my brother and let you know.... he loves 'em!
Guest
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
