u do realise that a NA engine has more torque due to the fact it dosent have forced induction to get everything going?
That i do and would work in theory......but i would still like to compare your torque figures with mine.....regardless anything else....
http://www.news.com.au/story/0,27574,25857567-29277,00.html
on another note....Australia's oldest hoon driver bahahaha
Edited by Krishy
Despite being able to immediately impound the car under anti-hoon laws, the driver was allowed to continue on his way. He has been ordered to take his car to a police station tomorrow, where it will be impounded.
"The speed he was travelling at ridiculous.''
Yet they let him continue driving to his appointment ... even when he showed no care for the 160kph+ speeds he was doing? :pirate: What if he'd killed someone after the cops let him go???
in the report the old guy even confessed to driving even faster before......he said lucky you didnt catch me before....i was going faster....
I mean seriously WTF is wrong with the police....i bet you if it was a 18 year old kid behind the wheel then he would be behind bars and car either impounded or crushed......talk about the cops always having double standards.....
Mate, I've seen 50+ year olds driving hyundais hooning thru traffic and they get away with it day in and day out.
Altho I did see justice last night at Regency Park. P-plater with mates in his "taxi" Falcon edging me to race him at the Regency Rd lights heading north on South Road. I gave it a quick squirt right up to 70kph (speed limit) ... 10 seconds later they screamed past me at about 100kph. The traffic cop (whom I noted was there earlier when I drove past) on his bike was hiding on the other side of the road, pulled out, gave chase and they got nicked :pirate: Yeah, I set them up a bit, but they didn't need any encouragement anyway. :P
how was everyones day?
Same as yesterday really, so-so. Woke up at 11, had breakfast, moved a garden shed, started surfing the forums, watched the chasers war on everything, and played some cod5 coop with a mate. Tomorrow i am back at work, i find that i am rather bored unless i am going something...such as working.
How about you?
only na nissan engines worth driving imo are v's over 3.5 litres.
wut?
yes solid lifters, lower emissions levels , and if its a series 2 it has higher torque cams in it. the output goes up to 206kw as well
  • RB25DET - twin-cam turbo (T28 Turbo) (245 to 250 hp and 319 N·m)
  • NEO RB25DET - twin-cam turbo (206 kW (280 PS) @ 6400 rpm, 362 N·m (37.0 kgf·m) @ 3200 rpm
________________________________________________________________________________
Released in 1998, the R34-series Skyline engines have a big emphasis on reducing emissions.
The existing RB25DET was reengineered to NEO specs, which apparently produce around one-tenth of the CO, HC and NOx emissions levels allowed under Japan’s 10-15 test mode. Further changes include a ball-bearing turbo, slightly larger intercooler, free-flow exhaust and revised ECU (which allows up to 10 psi boost). revised in late 2000 bringing extra torque (probably through a bit of extra mid-range boost).
Not sure where the RB25DET engine torque figure listed above came from, but it's actually quoted by Nissan as 30.0kgm at 4800rpm - just under 295Nm.
If one were to take the RB25DE and RB25DET minus it's turbocharger and compare the torque output, the naturally aspirated RB25DE would indeed make more torque, due to the 10:1 vs. 9:1 compression ratio. Now add the turbocharger back into the equation, where it rightly belongs on the RB25DET, and 230Nm vs. 295Nm tells the story.
Correct, however an N/A 25 will never make more torque than a turbocharged 25. Hence my "what the!?!?!" :)
Guest
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
