LOL ACC added me on their myspace page not too long ago..
must be desperate for an auto 31 to join..
whats wrong with auto 31's??? look at SLO-031....last time down the strip ran 11's......hopefully will be back out soon with even more power....or my 31....thats auto...and fun as hell...There are times when i wish it was manual....but having an auto outweighs that
also...my mate blew the head gasket on his sr20 powered 1600 the other day......first time he's opened the engine....bought it second hand nearly 6 years ago...and the cars done fast laps at mallala, phillip island, queensland raceway...collingrove..and run low 11 quaters....not bad for a red top sr20 i reckon
this has to be one of the funniest ways to explain how something works:
GTST
R&R = Rich and Retard (kinda like Paris Hilton but with less skank)
the standard R33 ECU will modify the air:fuel mixture by making it run rich and retard the timing when it senses something outside it's expected parameters.
quick lesson.
air goes in through the air filter, goes past the AFM (air Flow Meter) which sends a message to the ECU saying "Hey bro.. there is 12 air habibs coming your way"
ECU goes "No worries bro.. I'll douse them with 2 bits of fuel and burn the f**kers"
the air (habibs) go through the turbo and get all hot and angry like a bunch of lebs that just did 14 sets of bicep curls in a power cage, then through the intercooler to coll off a little, then in to the motor where they think they are entering a hektik nightclub only to be doused in fuel and burnt and spat out the back of the turbo and out the exhaust.
so..
The AFM (lets say is a Kiwi bouncer.. you know.. tough, but can't really count much) can only measure up to a certain number or air.
when you use a boost controller (lets say a hot chick bro), and you turn it up (reduce the length of her skirt and shrink the top), more air gets forced in to the engine (lots of habibs get calls from their cousins and they call go to this place and try to get in).
The AFM can only count so much and realises that there is too much air going in so sends a message to the ECU saying "Bro.. I only counted 15 habibs but I think that another 10 of their cousins snuck in... I'm not sure hey.. I didn't learn to count that many"
ECU goes "f**k you're a stupid coconut c*nt... now I have to deal with these habibs"
So as the habibs make their way through the turbo and intercooler (no doubt stealing stuff along the way), and in to the motor, the ecu douses them with heaps of fuel and makes all the habibs really wet with fuel.. this means that when they are burnt off, they don't burn well and so come out as darker smoke.
Because of his bad mixture (too many habibs in the one club), the ECU also retards the timing (closes the bar for a while) meaning that everything works really badly... all to protect the motor (hektik club) until the AFM (bouncer) gets his shit together and counts properly.
all this means that your car will jerk as if it's hitting some sort of cut or has a fault..
but it's just your car's way of telling you there are too many habibs.
How do you fix this?
Cheapest = A signal bender of some sort (Apexi SAFC is probably the cheapest)
this is a device which teaches the AFM how to lie to the ECU.
You turn up the boost, and 30 habibs arrive and run through the entry door..
AFM goes to the ECU "Hey bro.. I've just sent through 18 business men hey.."
Ecu goes "thanks mate. I'll give them the fuel needed"
this means that you get a leaner mixture and it all makes more power.
a better choice? after market computer.. there are lots to chose from.. do a search.
the after market computer (replacement for the ECU) is fully programmable and so can adjust timing too.. it can also mean that the coconut at the door doesn't have to lie, but instead, it is send on a few special classes and is taught how to count..
Hope this helps.
Guest
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
