What do you guys think of these wheels, to go on a black 4 door lowered car
I have been looking at CE28Ns, but they won't have much dish, at the offset I need. these however have a different design, so offer 3" dish on the rears, and 2.5" dish on the front. I reckon they would look pretty porn on my new car. I know they aren't a Jap brand, but I am not overly concerned. And they are half the price of CE28Ns. And no, they are NOT Chinese made fyi.
wheels i would approve of;
work euroline fs;
work euroline dz;
work euroline sl;
ssr agle premium;
ssr agle strusse;
ssr vienna dish;
ssr vienna sovreign;
garson zuenglein dr302;
garson zuenglein dr301;
piaa rozza stellars.
and a whole bunch of others are sufficiently filthy for vip style.
What a shit day!
I woke up with a headache. Did some housework. Watched the Crows lose after getting reamed by the umpires in the first half. Decide to go and wash my car and get done by a red light/speed camera on the way to the car wash. I was doing exactly 80kmph in an 80 zone and was well into the intersection before the light went red. F**king $300 odd dollar car wash! How can you contest the bloody tickets without risking an even greater fine?
I should have stayed in bed.
You'll get a sequential photograph set with the fine if they decide to fine you for it. If you were over the line before the light went red then I wouldnt be too worried because you'll be safe. Light has to be red before u cross the light for u to get the fine..
-D
i'd say $2000 for a scratched set and $2500 for a clean set. 33 GTR rims are around the $1300>$1500 mark.
I'd sell them for no less than $2200 as it cost me $400 to get them fixed up and 2pac resprayed and they have no scratches at all.
They're not made in China, but they're probably made in Thailand :happy: Ahh.. who cares anyway mate? As long as they're reasonable quality (at least with a decent manufacturers warranty) and you like 'em, that's all that matters isn't it?
I fitted a new set of rims to my car about a month or so back, Lenso D1R, in Hypersilver. They aren't Japanese brand name wheels, in fact I replaced a set of genuine Volk Rays with them, but they look better than the old VR rims - 18" vs. 17" - and are fairly light weight.
work euroline fs;
work euroline dz;
work euroline sl;
ssr agle premium;
ssr agle strusse;
ssr vienna dish;
It's all a matter of personal preference/taste, but most of those examples look like absolute poo to me! :happy: Not a fan of the VIP style wheel.
Guest
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
