With you on that one Shane! That place is always crawling with cops, cant say i've ever had the remarks passed that Dave did though!
Most definatly have not luckily!! Thats why i generally don't goto the smaller one if i can help it
Oil cooler atleast if its gona be limiter bashing for a few laps lol,
Where is Cubes these days? He used to post on heaps of forums now hes just fallen of the face of the planet?
wont be bashin the limiter weezy :)
have it in 3rd and feather the throttle :D
Mitch, a mate of mine works at JMS, I highly suggest you go with their deal, they will be making 9/10ths of f**k all just to get you back on road.
Wayne, Cubes left a while ago now due to many reasons, he still posts from time to time, but under a different user name
Put simply, I wouldn't take it out. Definitely be considering atleast a FMIC, probably even oil cooler.
fmic isnt a super essential if your not going out there and competing et. neither is a oil cooler.
both are great pre-cautions and do great on the track but in this weather and the fact that your only doing 30min intervals you'll be fine.
i was running the standard ca non turbo rad and no oil cooler and a custom supra fmic setup till recently for a few track days and it worked fine. the 30min breaks between drifts were more then enough of a cool down.
if you plan on going out there more often, then i'd look into the above things (mainly just a fmic) and you'll be alright.
Edited by Import S13
Howdy guys, bought another car to get from to and from work during the week, leave the skyline for the weekend :D
Its pretty awesome and starts first crank n' whatever :)
im pretty sure i was driving behind you going up brighton rd in the 60 zone into the 80 zone.
i was in the white pulsar sadan in the back seat having a beer :)
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
