I wish! Don't know whether to go for a FMIC first or suspension. All too hard cause I don't want to cut reo and cop a defect either!!!
I got to go speak to a suspension expert about lowering my car because I definitely don't want a harsh ride, being a daily driver. If I can get it 25-30mm lower with spring rates very similar to what they are now and of course correct camber I'll be happy.... don't really think it needs to be any lower than that.
do what i did. do it all in one hit. lol.
ill take you for a quick spin in the s14 some time, its firm, but it isnt harsh. and thats with my unpadded fibreglass seat. lol.
or you can go and spend big on bilstein gear, which going from nightcrawlers gear, is actually harsher than my coilovers.
A good puncture repairer can drill and glue a plug in there
yeah, ill see what tyrepower can do when i get it aligned on saturday.
test fitted the rims last night at grand auto....bolt straight on..rears need spacers to bring them out to the guard....they are APEC
i just need to swap two of the tyre over as they are 205/40/17...ill put my 217/45/17's pn for the back
Link didnt work for me Damo????
With the summer weather coming up steve i would be looking into a FMIC....i remember the days when i drove my 33 in the summer with the side mount and compare that to the same weather with a FMIC its unreal....FMIC does such a good job
I'll have to do it bit by bit so I can still drive it to work! We'll have to organise to go on another cruise up the hills.
Krishy, I know what you're saying as I drove it last summer. Starts to behave like a slug.... :D
Krishy, I know what you're saying as I drove it last summer. Starts to behave like a slug.... :P
Yeah my car runs the stock SMIC, last summer one afternoon when I was driving to work and my car said it was 45 degrees, I went to overtake someone on a fast road after they turned off, my RB20 felt more like a RB10. Thats without A/C on because it doesnt work lol. So needless to say, a FMIC is on my list - along with heap of other stuff.
im looking at hookin up a small electric water pump to my washer bottle with some little garden water sprayers between the cooler and the rad for some extra coolness when it all gets a little warm.
dave-o, Jenkies just ran his window washers to the fmic, so when you pull back on the stalk to squirt water, your spraying yo cooler not yo window!
That's cool (no pun intended)! Then in winter you can plug them back into the bonnet squirters :P
or re route them to the back wheels and join ragerz :P
damn you got to it before me.....i was thinking why not just tap into the hose that runs from the washer bottle to the jets.....that way spray the cooler and clean your window at the same time
cos when your cranking at 160 k's down the back straight at lala, the last thing you need is a front window full of water and your wipers going all frog in a blender
true true that.....Dave when you do this thingo let me know what is needing to be done
Where can you buy hobbs switches??
Im working out with our electrician how to do intercooler water spray kit and i beleive all i've got left to get is hobbs switch and reservoir/pump which is the easiest bit
Easy man, go down to bunnings and grab some spray nozzles from the garden section, then run your existing water hoses and cable tie them (so the nozzles spray in the right direction) underneath or on top of your cooler.
I dont actually have a washer reservoir :P FMIC piping took priority, gotta get the mrs brother to fab one up for me.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
