Easy man, go down to bunnings and grab some spray nozzles from the garden section, then run your existing water hoses and cable tie them (so the nozzles spray in the right direction) underneath or on top of your cooler.
I dont actually have a washer reservoir :P FMIC piping took priority, gotta get the mrs brother to fab one up for me.
Wicked.....
Thats odd....with my greddy FMIC i was able to retain the stock washer bottle.....interesting
After having a very pleasant 69 with his girlfriend, George remembered
he had a dentist appointment.
He was afraid the Dentist would notice the smell of fanny on his breath,
so he brushed his teeth, used dental floss, and also used a whole bottle
of Listerine.
As he arrived at the Dentist he also ate a whole packet of extra strong
mints.
His turn came up and the Dentist told him to take a seat in the chair.
Feeling confident and relaxed he opened his mouth wide.
The Dentist got close and asked " So, you had a 69 before you came here
eh?"
Brian exasperated asked " How did you know? Does my breath still smell
like fanny?"
The Dentist replied " No...you have a skidmark on your
forehead..........."
Guest
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
    • 100% agree. Best bet on an RB will be NEO, but even it will be a long way off. Emissions is one of the big reasons car manufacturers went to DBW and constantly variable cams. When cruising, open the throttle right up, but reduce dynamic compression so low, that it's basically an unrestricted air pump moving very little air.
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
