Which one have you got (M or LS)? How much of the reo had to go?
PM sent
Having a poke around, seems to be a real pain trying to find an affordable FMIC that doesn't require modification to the reo (which is apparently defectable and could result in insurance claims being voided :down:).
I've heard mixed reports from people on the JustJap stealth ones (some say they got it to fit, most others say it requires modification - including justjap). I've seen some posts say that particular Greddy FMICs fit without reo mods, and same for the Blitz FMIC kits, and AVO FMIC kits - but I always seem to find other posts contradicting it. Either way, it's enough to drive you nuts in an attempt to stay within the law.
That's the only thing that's stopped me thus far is the reo needing modifcation!
why buy an off the shelf kit then?
Just jap cores are cheap to buy and are just as good as expensive brand name ones
then all ya get done is get some pipe work made up, so nothing has to be modified
if you are careful how you mod the reo you will get away with it. i needed to take about 15mm off the bottom to get mine to fit. rather than just take it off the centre i trimmed it off an even distance the whole way along, and then painted it. It looks completely standard, the only way you would be able to tell is if you had two side by side.
+1 on that, cutting up the reo or bar doesn't jump to mind of things I'd like to do.
Also, was quite amazed when ringing around at tyre prices today. KU31 in 265/35/18
Wheel Worx - $275
Adelaide Radial - $305
Bridgestone - $325
Beaurepaires - $410
I knew Beau would be shit, but wtf!
Wheel Worx - $275
Bridgestone - $325
Beaurepaires - $410
did you forget to ring adelaide tyrepower?
ok, I got a question, Bomex body kits for 2DR R34. cool or gay ? Im looking at one for my car, found one cheap $500
front bar, side skirts like the top car, and rear bar , new in gel coat
i reckon the front bar and the skirts are cool, but the fake diffusers on the rear bar is a bit over the top
popped by andrews place before work this arvo, and went for a quick spin in munro's 35, f**k those things are awesome. relentless acceleration, and it seems so effortless...
... how much does a left testicle sell for these days?
he also seemed to find my car rather tough, quite a compliment from someone that owns such awesome machinery.
<snip>
sorta glad i went with 17 over 18, prices are retarded for 18's.
bit of left field here, but does anyone have hook ups in the truck accessories game
need some rubber mudflaps for the patrol, to cut down to size (the gay nissan plastic ones that have all the metal support framework rust over the years decided to break on the weekend - seems they dont like getting buried in sand and then pulled at funny angles when the truck is extracted)
Anyone know where I can get bushes for the rear upper control arms and tie rod ends? My mechanic rang nissan who told him that they only sell the rods with the bushes O.o
Also after a fuel filler cable/handle set with mounting brackets
-D
Edit - only posting here because the work is going to be done tomorrow
Speak to Shock Systems on NS.com, he sells all the bushes, and he's pretty cheap and in Adelaide.
thx for the heads up, but it seems like he only does web based stuff ;\
ideally i'd like to find someone in adelaide where we can get the bushes tomorrow and do the install
otherwise i guess i'd have to deal with the web so it'd be worth dealing with him i guess
its a shame he has no mob number
-D
When i did my FMIC install, the only Reo mods i had to do was drill 2 holes...which is apparently legal, its only if you are cutting metal out that it is illegal. As these are holes that bolts are going through, it is replacing the metal that gets drilled out. Also the FMIC i used, uses the stock piping, only had to mod the front bar a bit for the piping.
or more images here :P
Guest
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
