Someone said King springs. I wanna slam it.. but was told 2" would be to bad because even with rolled guards my tires are too fat.. not to sure about that.. 18x235 front and 18x255 on the rear?
id get adjustable shocks, if u get super low king springs, it will be too low, and if u get normal kings, you will either sometimes want higher or lower. if you have long term plans of track racing or track work, invest in some ISC coils, i have ISC N1's and i love them
i agree i too have ISC coils 12kg fronts and 10kg rears faultless Ryan is the ISC disctributor here and SAU trader he may do SAU discount PM him he is on these boards
does that make for a really stiff ride or its still comfy enough
I have HKS springs on standard struts and i love it
not even king lows go as low as your car :starwars:
and my ISC coils are about as comfy as coils get. still a bit stiff, but will also be good for when i do some hot laps at lala.
not sure, bought my car with the coils in. any way i can find out?
edit: post number 3333! and my total post number 333! spooky. woo. Krishy, good to see me and you are busy at work :starwars:
Edited by Damo_R34
Im an "educational support assistant" in an english language school in the city. doing the systems based work. also first aid officer, health and saftey rep, do my fair share of marketing and IT, and negotiating workplace agreement with parent company :starwars:
im a utility. if i played footy, id be a rover that can defend, and can also play forward, and coach the team on occasion.
Guest
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
