Here ya go ruby:
[IMG=http://i114.photobucket.com/albums/n273/Damo_s13/Untitled-4.jpg]
anyone else a big fan of dexter? love it! got S1 and S2 at home, almost finished season 1.
About to start it. heard its good.
My fav to date without a doubt is Breaking bad. unreal series. Honestly never seen anything as good.
also watching weeds
Has anyone here installed a Bosch 040 fuel pump into a R33 before? I got so far then got stuck....couldn't actually get the pump and bracket back in the tank. Looking for some help from someone that knows what they are doing.
Edited by Aberax
Damm Nissan quoted me a trade price of $97 for 1 Brembo bleed nipple. :D
Also my front window seal has had it. Leaking water into the drivers floor. $80 bucks for a new one
And replacing my fuel filter which is $30 bucks.
And the RB26 is 3K delivered.
Damm Nissan quoted me a trade price of $97 for 1 Brembo bleed nipple. :)
Get the part numbers, I'll see if I can do you any better
Already ordered the window seal and fuel filter.
Part number for the nipple is #41129S. I was hoping for 10bucks max lol
Might see if a s15 one fits cause i got some at the workshop.
I could do with some new window seals for my car too, how much are they roughly?
Thats not too bad i suppose, i would be after the windscreen, the 2 quater windows, and the rear windows....they look like they are deteriorating, i may replace them if/when i have the whole car resprayed.
also watching weeds
Yeah Breaking Bad is awesome
Cant wait for season 3
-D
Guest
