wasnt that the malpassi one ruby ? Ive had them die a few times on the RB30 and now keep a spare wreckers one in my parts box..lol
Yep. Malpassi. Are they commonly known to die? :P Are they repairable/rebuildable?
Guess I'll be removing it and putting the Nissan one back on.
Edit:
I've done a search and come up with nothing about common problems, except some can split the diaphram. From the sound it is making, I believe the fpr is holding 60psi (should be on 38-40) as fuel is leaking internally into (I assume) a split diaphram. Once full of fuel the noise stops and the pressure drops to about 25psi = one f**ked fpr?
Trying to find out more info. Google is not my friend.
Edited by RubyRS4temp
Its only $40 buy it now Damo.....get it man as your into that sport
Has anyone here installed a Bosch 040 fuel pump into a R33 before? I got so far then got stuck....couldn't actually get the pump and bracket back in the tank. Looking for some help from someone that knows what they are doing.
I have a Bosch 040 currently installed in the car but thinking of upgrading to a GTR fuel pump....
does anyone know how much power can/will a GTR fuel pump support???
the pickup on the GTR one is better then the 040.....on tuesday i was having some issues on the track....had 1/2 tank of fuel and going around the kink on the back straight at mallala the car cut out.....simply no power nothing....and then when the car leveled off it came back to life....same thing happened after the hairpin and coming onto that little straight before the S's.....so blaming it on the fuel pump.....
what else could it be? slightly worried now
if you had half a tank, it aint the pump, unless its mounted too high.
Well thats what i am thinking.....i havnt refueled yet so will be interesting to see how much it takes....i am thinking of switching to a NISMO one that has better pickup......what else could be the issue of the car cutting out twice on the one lap.....on the run the fuel gauge drop dramatically but when i pulled into the pits it was showing that i had 1/2 a tank?????
I know the Stageas have a little 'anti-surge' type sealed craddle the pump sits in. This little craddle is filled with the returning fuel from the fpr. Does the Skyline have something similar? If the pump is suspended low in the tank with no anti-surge device, you may in fact be experiencing fuel starvation ... especially under track conditions/speed.
I dont think the skylines have that ruby....correct me if i am wrong please.....but i do think that what i experienced was in fact fuel starvation....now i am begining to think that a NISMO replacement will be better as its close to what the stock one is.....ie pickup and mounting....also does anyone know what power will a NISMO fuel pump support oh and the price...just really want to get that bit sorted out for the next track day
just make sure the filter is clean.. scott had this problem with his walbro..
was mounted too low and the pump would pick up shit off the bottom and clog the filter.. car would stall and run like shit..
cleaned the filter, moved it up a little and was fixed..
try this?
they are widely used in massive V8's and drag cars cos of the sheer volume of fuel that they can deliver. their website is not particularly helpfull CARTER FUEL DELIVERY i'll try n dig moar up for u
..::edit::..
the smaller ones make great lift pumps. the rotor guys love em
Edit:
which model fuel reg do you have ruby ? they have 3 or 4 models for EFI, some, stock replacement, rising rate, racing hi pressure ???
I would suss you can rebuild the regulator diaphragm and spring rates, but doubt you would need that... the nissan one fails when they get older believe me...lol ,
this is what the regulator looks like inside
you could go this route
Sard fuel regulator
or this one for the 260
Nismo fuel reg
just to throw it out there, carter fuel pumps are tits! they have a massive flow rate:pressure ratio and they are reliable as the sun
hmmmm I would go elsewhere , being from USA where Carter is a cheapo brand , and in my past V8-V10 days I wouldnt go for one
they tended to get bad flow rates on hot days , and would vapour lock easy since the pressure would get too low. a royal pain in the ass
but to each his own
have not seen them vapur lock with the rotory vane ones. but i have only used them on a 186 with a 179 head, and the rolla
http://www.weatherzone.com.au/satellite.js...lye=1&lyf=1
lotsa lighning coming
wow cool I love the lightning,, time to get the camera ready
Guest
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
    • Set of R33 GTST Calipers, Rotors and Pads. Calipers just taken off my car, rebuilt about ~30,000km ago. Rotors have done about ~20,000km total since new. Pads have plenty of meat. One set is DBA XP (road, hills) and the other set is Forza FR6 (track) Still working perfectly, not rusted, or seized or whatever the hell that greets used brakes. All clips, bolts, retainers, slide pins etc included. Also have OEM handbrake shoes I can throw in there if you're doing a conversion. $650 for the lot, SE Suburbs Melboune/VIC
    • I feel I have covid right now. I spent the time between Dec 21 and Jan 31 pretty much working 16 hour days on the car after it got back from paint. It turns out you generate a long list of "things to do" while the car is off the road but functional. After going to visit my mate for a "Couple of hour job" doing the brakes, 3 full days later I got home There was more on the list, (it got added to while sleeping on couches) but as everything on the list got enthusiastically crossed out as it happened, I've actually forgotten what they were. From memory there were bushes that had to be pressed in and out, washer jets to fit, etc. Some Gregging highlights: 1) The panel shop covered up my washer jets and painted over it. Good job, I think. We had to drill the new bonnet to fit new ones, which was understandably extremely scary. 2) My handbrake on the RHS is f**ked. After never adjusting it forever and learning on the fly, this one is still on my to-do list. It tightens when you pull the lever, but at about 10% of the tension that the passenger side does. Thoughts on what causes this would be great. 3) Pouring an entire liter of brake fluid over the reservoir because I forgot how to use my pressure bleeder. DON'T PUT FLUID IN THE RESERVOIR. IT WORKS BY USING PRESSURIZED AIR NOT PRESSURIZED FLUID.   471907729_9242915229093447_2708910336906717367_n.mp4  I can confirm the vents work great though. 4) Some of the bodykit fixings were f**king awful. I'm talking screwed in with what was at most a 2mm screw, and could flap the kit around by hand. Too many others to mention. They came in, went out of my brain forced by other stupid tiny things that came up and "While the car is on the damn hoist we can fix them" which was a mission in and of itself, because the car has skirts and is thus a pain to put on hoists. Because we had to buff the windscreen to get rid of the overspray, I also had to very gently wash the car. The "Run 3 wires" task was to re-attempt another gregging thing which was: The LS1 ECU in Australia does not have oil pressure wiring because the Commodores do not have a 'real' oil pressure switch The Corvettes in the USA do have oil pressure wiring because Corvettes have a real oil pressure switch. The ECU is the same physical ECU. So what I could do is pull the ECU apart, run 3 more pins and run it to the OEM oil pressure ECU, and the ECU should do this. What actually happened is that Greg did this with some not-so-proper-wiring/connectors to the ECU pins which 'might?' be okay put the car back together, and then the fuel pump wouldn't prime. So you can imagine I immediately undid all this work, put the ECU back into it's original configuration, thought I'd do some more research about what connectors the LS1 Ecu actually uses... and try again later. Except still no fuel pump prime. After a lot of sadness and checking/double checking it turns out it was the relay in the boot that controls the fuel pump. All I did was switch the trigger wires and it worked fine. I looked at the relay and it was covered in bog dust and was unknown years old. It's since been replaced and working fine. After I got the actual connectors, and the wires were ran I gathered my strength and repinned the ECU and Voila! I apologize for these MMS  472164532_8829400773820369_5410969472548349643_n.mp4  And even via ODB2 on the headunit, woo. Now Torque Pro can raise hell on track if it gets too low. It has a wonderful EMERGENCY_DISTRESS_SINGAL style warning if it goes below a certain threshhold. 472585876_9345134268844369_146554337148747327_n.mp4 TLDR: Car great. HFM kit works. So much cleaning. Buy my old stuff. Thanks.
    • That's a hell of a question right there and so broad that you could get 100 different answers and have them all be correct.  To avoid me typing up a 2000 word thesis that doesn't answer your question, do you have specific things you are unsure of? Does the car currently handle in a way that you don't like? Or is it closer to, you think the car drives fine currently. But you'd like it to be better, but you don't know what that 'better' is or what that 'better' feels like?
