Got a spare 23k burning a hole your pocket ?????
- Brand New R33 GTR N1 Long Motor
- Fully Assembled
- All Components Brand new
- Ready to Install
- 500PS Package
Engine Package Includes:
- Front Differential
- Sump
- Tomei 1.2mm Metal Head Gasket
- Tomei Metal Intake Manifold Gaskets
- Tomei Metal Exhaust Manifold Gaskets
- Tomei Poncam Type B Camshafts (260 Deg/9.15mm)
- JJR Adjustable Cam Gears
- Sard 700cc Injectors
- Sard Dual Entry Fuel Rail
- HPI Stainless Dump Pipes
- SSI Premium Stainless Exhaust Manifolds
- HKS GT-SS Twin Turbo Kit
- Gates Strengthened Silicone Timing Belt
- Trust Clear Timing Belt Cover
- Nismo Engine Oil Cooler Sandwich Plate
- Nismo Engine Mounts
- JJR Direct Ignition Coil Packs
- NGK BCPR6EIX-11 Iridium Spark Plug Set
- N1 Oil Pump
- N1 Water Pump
- Cooling-Pro Silicone Water Hose Set
- Ceramic Coated Plenum
- R34 GTR NUR Coil Cover Emblem
- HKS Oil Cap
- New Genuine Nissan Air Regulator
Engine Internal Specifications:
Displacement: 2568cc
Bore: 86mm
Stroke: 73.7mm
Compression: 8.5:1
Block: N1
Pistons: N1
Conrods: N1
Just Jap
Got any pics Dale? Looking for a more "fitted" rim for my 31, has some sort of 4 stud Nissan rims on it with a very high positive offset.
I also have some 17x7 rims that you can have for $550 they are copies of the rims i have on my 180 (Volk GT-P's), they have 3 legal tyres on them and one that has to much camber wear. I was going to use the 17's fro track rims but now that i'm fitting a RB25 i'll be going 5 stud.
Here's the pics 17x7's on the LHS and 15x6.5 on the RHS;
Edited by D_Stirls
ruby, malpassi's are know for making the squeeling noise on startup. sometimes from new. havnt had any fail on me, but i wouldnt doubt they do. personally i like aeromotive. has yours got a black or silver top? black is 1.7:1, silver is 1:1
I think my car is the anti christ! Just finished new pads and rotors, gearbox oil, diff oil, engine oil and filter change and a good wash down under the bonnet. Take it for a spin last night to bed the rotors and pads in, and discover i now have another coolant leak! Seems to be coming from around the water pump, that was only put on 10k ago! Hoping its just a loose bolt and not a shagged pump!
yeah i know what thats like
i got a new isc52mm radiator, n1 water pump, racing hose and nismo coolant put in earlier this yr
next day i lose 20% of my coolant via a cracked hose in the heater core (back of the engine, real pain in the arse to get to)
ahh well
two steps forward, one back - always the way with the older cars
-D
Guest
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
