"Premium100 is a high performance petrol with an octane of 100, which is the highest rating available in the Australian market. Ethanol is a natural octane enhancer - adding 10% ethanol to petrol boosts its octane number and its performance. Ethanol helps the other components in petrol burn more completely. It also has a cleaning effect on the cars fuel system. Premium100 will give your car more zip! "
reading from that it should b better then BP ultimate. i might have to give it a try... i fill up tuesdays so might use it 2moro. any1 tried it?
Just be careful with ethanol blend fuels! I put some 98/10% ethanol in mine and the knock reading skyrocketed. Was tuned on Ultimate 98, tuner said that any ethanol blend fuel is trouble unless you retune for it. Due to the amount of extra fuel needed and less timing because of higher burn rate. My knock went from 30 on ultimate to over 200 on ethanol blend!
Oh and Damo, go for the chrome/orange globes. Last thing you want is nice clear side markers with daggy orange globes.
I am speaking to Luke_ENR about it, which seems to be clearing it up a bit for me.
I get the 040 in the cradle, but it doesn't go back into the tank. I now have a theory that the end/base of the 040, needs to be in the same position as the OEM pump. I was mounting the 040 a little bit further down, where the "C" bit of the cradle is, was where is was putting the line on the 040. the "C" bit, holds the OEM to the cradle as it has the pickup go through it.
ffs I couldn't have imagined it being so frustrating trying to buy a "near new" car .... I think I am on a winner this time - we will see what the mechanical check picks up on THIS one tomorrow.
pritty sure there is a guide on the site??
also i thought that the 040 is not a direct fit replacment?? but maybe thats just for gtr's
It isnt, you need to modify the cradle...but i think i know what to do now. I did look at the guide, it helped me a bit.
lol. turned into quite the mission for you. fingers crossed this one pans out. sedan or coupe?
Guest
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
