mudflaps are like rollerblades?
lol. i used to fruitboot... used to be damn good at it too.
/shame.
the guy likes to take the dirt track instead leave him be, its a free country :D we all know you live down that same dirt road scandy or should we call you scatty
lol. difference between me and matty, he enjoys the dirt track frequently with other men.
i just go the dirt track when all other roads are closed.
:happy:
... did i say that out loud?
the guy likes to take the dirt track instead leave him be, its a free country :happy: we all know you live down that same dirt road scandy or should we call you scatty
I'd just like to go on record by saying that I support marriage of 4 wheel drivers to other 4 wheel drivers.
at least it would get the heathens off the city streets :D
-D
lol did you actually have the fruit boot as in the bright coloured blades? i believe thats where the name started from thy wood pushers
n u do relize i still blade, havnt been for a couple of months but ill get the dust off em soon. need to get my 540s on film
n hey man dont knock gay couples, for every gay couple thats 2 less competition i have for the women in adelaide :happy: hell i wish there were more fags in this town
with people like yall around i see a bright future indeed :D
Edited by Inline 6
lol. plenty of 'otherwise inclined gentlemen' in adelaide. (i got majorly chewed out and refused service from the ex lady for refering to a fag as something rather crude today, lol)
most of them hang at hq on wednesday nights. makes it real easy to throw some moves on the rather large amount of easy ladies that frequent slash dance.
and yeah, i rocked crazy colour blades for most of my time. one was bright f**king neon pink with purple wheels, the other was basically dayglow orange with lime green wheels.
yeah, i rolled on crazy shit.
tamed up at the end though, just ran full blacks with neon blue wheels in polished stainless steel rails. was baller.
think ive still got em around somewhere. will have to have a look. another one of the things id love to get back into. shame my knees and ankles are proper uncooperative thanks to years of abuse.
IS I.D CHECK IN REGENCY OPEN ON WEEKENDS?
Sie müssen das lokale reichsfuhrer für irgend solches "regency" Überprüfungen. Sie müssen in den Leder auch gekleidet werden und mit Ihrem eigenen Schmieröl kommen. Wir können und tun Körperraumsuchen. Und wir sind am Samstag geschlossen, weil Samstag ein heiliger Tag ist.
Alle mögliche Fragen, meine kleine Aufladung lecken?
-DieterMar
-DieterMar
lol good old metal grind plates, twas the only way to slide :happy: i used to have them and also had custom made sole grind plate aswell
fortunately i never went into the crazy bright colours, they always look black in the end from all the grinds n stacks anyway. back in the day i had $270 dato and $400 pair of blades had my priorities straight.
these are my new 1s, 1st pair ive actually liked the look of, n yes mine have wheels on em unfortunately 4 of them are fake wheels in the new compramise speed for grinding
n the x lady musta been gay or something :D
Edited by Inline 6
-DieterMar
:happy:
20 Tage am Kühlräume
Edited by Aberax
<snip>
nice boots man. i rate em. how much and where?
... shes only half gay. :mage:
Guest
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
