Abe, place the pump in the exact same position as your stock one. Make sure the bottom of it is inline with the stock one. Looks like u will need to cut the hose alittle shorter and connect that up. Cutting the bottom bracket off is fine as u need to. After that hose clamp it on and slide it into place.
I am slowly getting there with the pump.
I finally stuck my whole arm in there and managed to get the pump into position, that was with out hose clamping it to the cradle. I have now hose clamped it, cut the tail off...just waiting for it to stop raining, while having lunch.
Also, petrol melts the sound deadening in the Tyre well.
mitch, i dont think a 26 head gasket will go on a 25, they have different oil lines
the gaskets will be the same appart from that the 26 will have larger holes where that head studs. The proof is that with 25-26/30 conversions both the 25 and 26 head will fit the 30 block without modifications.
i wasen't quite sure, because the 26 has an oil feed to the head blocked off where as the 25 keeps it (for vvc)... so wasent sure if the head gasket for the 26 still has the hole for the blocked off feed or not hence played it on the safe side. Tho isn't the hole a different shape on the 25, smaller and tear drop shaped? but probably wouldnt matter since the 26 hole would once again be larger...
need the chains coming off the back now so u dont run them over.
thats the next bit im working on, definitely going to need them when i do the fronts thats for sure
lol. plenty of 'otherwise inclined gentlemen' in adelaide. (i got majorly chewed out and refused service from the ex lady for refering to a fag as something rather crude today, lol)
most of them hang at hq on wednesday nights. makes it real easy to throw some moves on the rather large amount of easy ladies that frequent slash dance.
needs more twink reference haha
hmm... just found the same set of wheels i want (albeit in a different colour, and without tyres) brand new for $90 more than i was gonna pay for use ones... really not a fan of the colour though...
was just reading a thread on ns.com
1800 defects in the last 8 days!! hahaha WTF!
would like to know what suburbs this is happening in!
i know the west subs have cops galore!
You said they said they heard? NS.com is hardly a reliable source. :down:
I have a soft spot for Capellas lol,
So badly want something old school Mazda with a 13bt in it.
Or a ke10 with a 13BT
Faaark yeah the 200m powerskids would be awesome
Edited by Weezy
Many years ago, I helped a mate fit a 12A into a KE10! Last I saw of that project he was getting it wired up. Don't know how far he got. But even a 12A in something as small as that would have been fun!
Guest
    • I would be looking at the tune mate. How do you know that you have such a low dynamic compression?  I had to dumb mine down because it was too jumpy when taking off (too much torque).  What ECU? Do you need help with the tune?
    • Surely the cam timing is set to something stupid at low RPM?
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
