Ok well in easy to understand terms.
I push the power button on, the fans start up and the keyboard lights up for a second, then goes out. The mouse doesn't light up. There's no beeps like there usually is, just the noise of fans spinning.
I've unplugged the screen at the back and a message comes up saying connect back up, but the light next to the screens power button keeps flashing.
hey abe, u got msn? wanna chat about my comp :bunny:
yes, yes i do. It is in my profile.
Could be a few things.
1. GPU (Video Card)
2. Mobo
3. Ram - unlikely, but i have seen stranger things.
spend the day 'installing' krish's new turbo. bit of a head f**k.
only 3 out of 4 of the nuts for mani-turbo studs would screw on because one kept fowling on the housing, so thats off to be machined this week, and the wastegate design sucks. flap opens about 5mm before it fouls, so ive taken it to andrew and it looks like itll be getting the internal blanked off, and an adaptor for extrernal gate made up.
anyone got any hookups for tial 44mm gates?
I was gonna sms him and ask him how you guys went, but you just summed it up for me. Lucky he has a daily...unlike me, but i am due for a bit of a holiday. My upgrades should be getting done soon, say 1-3 weeks. I am going to go through Horsepower In A Box, as it is just round the corner from my work...sort of.
Edited by Aberax
it went alright. had a few moments where we were missing a few odds and ends, but it went pretty smoothly until those 2 issues popped up. wouldve been about a 4 hour turnaround. with any luck he'll have it back on the road within 2 weeks.
Split dump wasn't it? They are what suck not the wastegate.
Bellmouth FTW
i use those gauges too. pretty accurate. shall have to get a few more soon.
Bellmouth FTW
negatory. no split dump. kinda hard to explain, but theres another piece that bolts to the back of the turbine housing that holds the wastegate flap and has the vband for the exhaust flow on it, problem is this section is shallow for the wastegate flap to properly open.
Edited by scandyflick
I know what yoru talking about, it's a shit design i can't see how you can't get boost spiking with that setup.
What turbo is he using?
Hey Dale, are these the guages you use?
Yeah thats the gauges that i use, if you want a set matt can get them through his business.
its garbage. i was expecting a few things to be not quite right, but thats just shit.
its a hypergear tr28 or some such. part of it is sitting on my desk, half of it is at krish's place, the rest of it is at am performance waiting for krish to give the ok to fix it.
and on the topic of gauges, ill be speaking to you soon about a couple oil gauges.
So who's good with computers? My home comp won't load anything. You turn the harddrive on but it just looks like it not doing anything, only thing moving is the fan :( . The light on the screen just keeps flashing so it looks like it's not loading the hard drive arr help plz
i have tomorrow off if you want to bring it over, I'll sort it out
on other news, go rear ended today on the way home from writeoffs place
chick decided to step on the gas when the lights went green - i think she assumed i was going to gun it ;P looks like minor damage only (paint and one of the plastic clear reverse light covers) but won't know for sure till my mechanic gets a decent look at it - went straight to holden hill to report it - cop there was cool as, told me about his xr6 turbo and came out to scope the car - said I had nothing to worry about as far as defects was concerned, which is great news (considering thats my aim) and also said that I'd got a nice example and was good to see someone taking care of their ride >:) *thumbs up to holden hill branch*
-D
Abe I'm 99% sure it's the video card. It stuffed up about a yr ago, replaced with a second hand one where the fan wasn't working properly for it.
Any idea where to get a basic video card from? Don't use the comp for games etc so just need a basic one.
Cheers.
No worries let me know when your ready
Cheers.
go to MSY - they pretty much have the cheapest retail sales in the state
-D
^ That sucks balls Ben. Hope she's insured....?
not sure - it wasnt her car - she said she doesnt know if the car in insured but would pay me cash for the repairs - i got the cop to check her details up and it all comes up as legit so I don't think I'll have to worry about dodgyness
6 weeks before the show too. none to pleased
-D
Guest
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
