Abe I'm 99% sure it's the video card. It stuffed up about a yr ago, replaced with a second hand one where the fan wasn't working properly for it.
Any idea where to get a basic video card from? Don't use the comp for games etc so just need a basic one.
Cheers.
ur diagnostic skills are fail... =P
if i was a betting, wow, i'd probably put my car up on it not being the video card =D
could be soo many other things making it do that... number 1 is the power supply! i'll also throw my hat in the ring and offer u some free help, just lmk
ps. hoodie thread up soonish
Luke, i just worked out what it is... =D
but i'm not going to tell you what it is because if you try to fix it and mess up you could end up killing stuff!
however i will say this, whoever you take it to will set it up and it'll probably turn on first time, straight away and u'll both be like "hu?" =P
^ what a graph card that's not seated correctly in it's slot?
wow, i should actually start taking bets with people on this! =P
no, as i said before, nothing to do with vidoe card... unlikley that one would just randomly pop out!! =\
Tell tell..... I'll give good prices on jap stuff lol
just drop round and i'll fix, fix!
edit: and coz u get me good prices i wont slug you the $40 i would to a customer for fixing it =P
Edited by Fishpaste~
With big turbos cams can make you up to 50kw depending on the size of the turbo and the amount of head work done as they allow you to move the turbos into their efficiency range, but like chad said with small turbos they won't affect peak power much but will allow you to move the power around the rev range and can get you some nice gains on torque.
Here's some graphs from when we were playing with the cam gears on my car.
cheers man, might go ahead with these os cams
see what willal can do with them once i get a new exhaust fitted
Hey guys, I was wondering if any of you have heard of GT Autosound in Glynde, and if they are a reputable workshop. Thanks in advance.
yeah their pretty good their man and reasonble prices with what you get out of it
Sweet. How long u reckon it would take? Have to head down to Marino around 9am so could pop by after that?
Cheers.
prob 15 mins all up... thing is i'll be at uni from 9 till 4 tomorrow, then have district basketball
so either drop round tonight or tuesday!
u gonna be up for abit still? If u are I'll pop around soon.
George and Theo are excellent guys. Havn't had any work done by them, but never heard a bad word about their work :ph34r:
Guest
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
