also did the all Japan day at shepparton a few weeks prior more strangers cars!
What you can try is to disconnect the hose with a clamp( or bypass ist with a short tube) . Its under the manifold on the left side . so you can check if it has any effect on the cold start
refering to your cold start Problems this might be interesteing to you https://www.carpassion.com/forum/thema/58441-308-zusatzluftschieber-reparieren-und-einstellen/#comments Problem :you can`t get by without removing Manifold. I Put some Brakecleaner into the Hose to remove the Oildebris, most time the slider is stuck or boken-
