if you get stuck, ask Jack88, he's installed one into his car before
-D
done about 11 of them lol.
you can use a 150 - 300 watt inverter but there fairly power hungry or you can use a DC - DC power supply which replaces the 240v unit in the xbox, need to rewire the loom in the xbox for it though. PM me if you need to know anymore.
Jack
Yeah keen for it bud. I'll get back to you for sure on that.
Currently licking my wounds from the track day at Lala. 3rd session I collided with another bike at turn 5 and we both ended up in the dirt. Bike has a fair bit of cosmetic damage. Crushed my hand and broken a finger. Bruising is looking pretty awesome now :)
Time for painkillers and beer!
Getting some respray work done on the bumpers on the car this weekend. should look decent when its done
-D
Looks good, where you getting it done?
i got monkey bars yo'
You still need to send me pics of those rims.
Would look better with a front lip :)
Truth!
However. My R32 has stock suspension yet I still manage to scrape the lip in some places, isnt that the reason why he removed it?
Cheers...Can i play on your monkey bars? :D
That sounds weird. :bunny:
front lip = wank
the car is setup for handling on the road, and despite it not being as low as a track car, the lip does not cut daily driving - always scraping shit, steep driveways etc. as it is with the lip removed, i still have my zorst scraping stuff - that i dont like...
i would chuck it on if it would line up with the rest of the bodyline, but i do like the look sans lip - less 'kick me in the balls' for the po po
i can understand the lip for those who track/weekend warriors/wannabes who need that 0.01% of downforce but each to his own :bunny:
-D
Road & Track Dyno, - theyre my boys
Dont trust anyone but these guys to service my R
The guy who is doing my cosmetics has been pulled out of retirement as a favour to the owner of Road & track, mainly because I'm doing a complete overhaul of their IT, but also because I've needed these blokes to do a stupendous amount of work for me lately..
Spent a few hours there today while copying over their databases, met Charlie Kovaks and saw the 6lt V8 gen3 that Gil Cameron is building for his racing ute... veeeeeeeery sexy
-D
front lip = wank
i can understand the lip for those who track/weekend warriors/wannabes who need that 0.01% of downforce but each to his own :)
-D
dont you also loose your brake ducts??? =\
Guest
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
