The Sa Wasteland
Cubes
 Share
My car is always under cover unless I am driving it :) . For some reason I thought you lived Southern Dion haha.
Love hearing epic thunder
Haha nah Im like a MAX northie lol.
Yeah my car is 99% of the time undercover, except when Im at the winery. Even when I work at BIGW I have undercover parking :)
I don't daily mine anymore so its under cover untill the weekend, some times I don't even get the chanse to drive it on the weekend lol.
Off to the crash repairer today to get the front 1/4 panel chabged with brand newy and sprayed, from when that bitch reversed into me haha
Yeah I have a daily, but sometimes I get sick of driving it lol. The only time I got behind the wheel of the R32 on the weekend was to reverse it in and out the garage lol
Good to hear your car will be all fixed now :)
lol sounds like mine, just depends whats going on the weekend. generally though i fill up on tuesday n go for a lil short drive everyweekend just to make sure nothing go's stale from it sitting for too long.
Here is what colliding with another motorbike at 80kph can do to your hand:
Spending $350 on gloves pays off. Could have been alot worse ... a broken hand/wrist instead of broken and bruised fingers.
Working/typing one handed sucks :)
Looks pretty fked Ruby!
Absolutely pissed down 20 minutes ago and I was in the car (mine was clean too), I couldn't see 30 metres in front of me with standing water all over the road!!!
Ahh the only joys of working in a factory 3/4 empty now is the storage space :) Cars under cover and outta the rain/hail...whats the bet it hails on the way home though? f**king washed it yesterday as well....
You northern boys, what do you do with your car oil after you've done oil change?? I've got like 50 odd litres that i've gotta get rid of!
paid for my oil cooler back on 12/08/2009, the guy has been sick as with a chest infection, and then he said he will post it on 11/09/2009, no correspondence since. Hes a moderator so im sure im not getting ripped off, but just getting impatient!
Tip it down the sewer or leave it on salisbury highway somewhere.
nah just playing :) there's somewhere around you can legally dump it for a fee i believe.
were currently building a collection at my house to get rid of in bulk.
Edited by Inline 6
Wish my hand got off as lightly as yours Ruby when the bandsaw at work took a bite out of it:(
Yoicks! :) Powertools are evil.
My pinky and middle finger are bruised, but I can move them. My second finger got pretty crushed in the impact ... its purple and black all over. Was as thick as my thumb yesterday, but most of the swelling has gone down now. Its just numb constantly now ... no pain, unless I bump it or try bending at the knuckles. The fracture is between the knuckle and finger nail, so there's nothing that can be done to it, apart from keeping it out of harms way.
The gloves are brilliant and offer maximum protection (same stuff as what the MotoGP boys wear), but the tips of the fingers are still only covered in leather only. At 80kph it isn't going to be 100% protection anyway. :)
Guest
 Share
    • Time for millspec wiring, MoTec electronics package, Bosch Motorsport ABS, let's goooooooo!!!   Maybe as @MBS206 suggested, just swap out those stupid blue relays near the ECU plug.
    • My only regret with the NC MX5 was no space for a spare, even a space saver doesn't fit in I do have a couple of those puncture repair spray cans, but if I get a large puncture, or sidewall damage, I'm screwed until a tilt tray turns up I'm thinking I might get one of those 4WD style of puncture repair kits that have that rope stuff and glue, whilst it will kill any hope of saving a tyre, it might help getting me out from some backwoods road far enough to find a actual tyre shop if the first can of tyre fix doesn't work I'm keen to see how your new toy pans out Uncle Duncan, I'll be moving to the Highlands next year, you'll need to shout out if your heading to Wakefield, whilst I've lost my balls for happy laps, I still love watching those that can
    • Yeah not sure what the warranty was, but it will be years outside it.  I've shot Link a message, will see what happens, I'm told their support is good. It is a plug in, so its a Link board in a factory case, very easy to access both sides of the circuit board by removing the top or bottom cover. To be fair the the Link, although I've checked to the factory connections and wiring specs, as we learned with Neil's car in the early days not all ECUs source power the same way. He'd been running a factory ECU with no trouble for years, but when we plugged a PowerFC in it wouldn't start up, just kept cycling power on and off. We worked out that the car was missing one of the 10a fuses "Electronic Parts", and to Neil's knowledge it had never been there. Turns out the ECU pulled its main power from that source not the same place the factory ECU did.  Point being....there are multiple battery and ECCS power sources in the factory ECU, and multiple grounds as well....not telling from the outside exactly what the Link uses (and doesn't use)
    • Now, thanks to sonicii, onto the uneven floor from a tyre sticking 100mm into the boot space. I looked into options to raise the floor to the level of the tyre, and ended up going Extruded Polystyrene (XPS). EPS is what I normally think of as polystyrene, the annoying tiny balls that get glued into a flat sheet but XPS is quite different, much firmer and doesn't crumble if you touch it with anything. I also looked at things like heavy duty seating foam but XPS seemed like the right way. I picked up 3x 1200x600x50 sheets for $40ea. Initially I was looking for 100mm sheets because I needed to make up a 100mm gap, but as it turned out 50mm was available, much easier to work with and made it simple to store the tools I used a simple 15cm foam cutter to make the shapes. With some practice I was able to make reasonably clean cuts but I don't think Clark Rubber are going to be calling me to offer a job. https://www.ebay.com.au/itm/405092315205?var=675175481574 First layer in place, 3 dimensions are tricky! Second layer in place, bringing it to level with the top of the spare Cutouts in the top layer for the tools With floor back in place, nice and flat with 100mm stolen but no real impact on usability
    • Sounds like a good idea to me moh
