$220, that was a touch up on an existing tune.
Sweet. Now that I got my fueling and CAS fixed, I wanna get the Stagea on the rollers to get back those lost ponies.
Did a compression check a while ago and thankfully no compression loss or blown rings etc. Thankful that I babied the stag around when I knew it wasn't running right.
I wanna get to that turbo/dump gasket leak this weekend too.
damo that boost curve looks consistent with the r34 turbo
a really good ebc may fix up the peak & hold boost, or better yet a fully tuneable computer
as it is it isnt a bad tune...
i have a power fc, but a shit boost tee.
ah simple then, save for the power fc boost controller - scour ebay, JPS Trading Ltd is a good trader to search thru
you can see where the boost T isnt cutting the mustard from 80-120kmph
see how a decent boost controller works better ?
edit: the dropping off of boost was from restricted exhaust, much flatter now at the pointy end of the graph
tune of new piggyback ecu on 8th Oct, update then with a 250+ kw tune map
If you still have the factory boost solenoid in line then i expect if you had a your boost graphed then this is what it would look like (This is a mates figure from his 33). How much boost are you running? Is yours an auto or manual because that figure looks a bit low to me (depending on boost). The other thing that would be playing a part in the hole is the VTC timing not being perfect.
Edited by D_Stirls
still dropping off - but fuelling is the issue here
again, on 8th oct bigger injectors slot in, so will update some graphs for discussion.
Id suggest damo that a better ebc will do the job well. p-fc boost controller.
Where is the dropping off boost shown?
The graph says 10-11psi, when he rang i said around 10.5psi would be fine, and i assume thats what its on, hard to read from factory bar guage. Its a manual.
Its a turbosmart bleed valve, and always has lost boost from 4000ish to redline since it was fitted.
:D This is gonna sound pretty gay. But for some reason Damo, You were in a dream of mine last night. And you drove a VT commodore.
Thats sweet Craig. and by "drove a VT Commodore" i hope you mean "watched you have sex with Megan Fox"
Guest
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
