from 120 thru to 180 the downward line shows that it was dropping from 14.7psi down to 12psi at WOT in top gear
That's the torque curve not boost; and torque will almost always drop off in the top end as you have past the point of Max' VE (volumetric Efficiency) and rate of change of power has began to decrease i.e.torque.
Here's an example; these two print outs are of the same runs; one showing torque and the other showing boost. See how the boost is dead flat but the torque is still dropping.
Edited by D_Stirls
Thats sweet Craig. and by "drove a VT Commodore" i hope you mean "watched you have sex with Megan Fox"
hahah strange night indeed. One of those only half sleeping nights. Had the laptop next to me waiting for downloads to fin all night. Hence weird dreams.
I only really remember you being in my front yard. drinking. then kicking the wheel of your commodore with your foot.
I woke up today and thought to myself 'wtf'
i can't see how unless they are rated higher. First i would look at whether the factory solenoid is still in line if it is then bypass it and it MAY help a bit. But the others are right a EBC is your best bet as they minimise wastegate creep and do a much better job at controlling boost.
If you twist my arm i might even sell you my new one that has only done 500km since i'm looking and changing to a Turbosmart E-Boost 2.
P.S> so is your car Auto or Manual?
Its a Blitz DSBC Spec S.
That power is low then since your car is a manual.
you should be pulling a lot better numbers than that graph of my mates, because the only mods done to it were; Full 3 inch exhaust and FMIC, that's it. Doesn't even have a boost controller, Hence the boost curve . So it's running standard factory fuel and ignition maps it's just with the freed up exhaust and intercooler they run up to 12psi.
So even on 10.5 psi you should be closer to 200kw than you are.
Edited by D_Stirls
yeah stirls, I know its a torque curve, ... being my car and all the tunes etc I just happen to know at that point of time with that tune the boost dropped off as described
alls good now tho
:D
So if I were to put a FMIC on my car which is stock except for the 3" turbo back, I could go to 10 psi without any other supporting mods?
with his car that is what we found, though every car is different and if you have a look at the graph it's a far from ideal boost curve.
Also before you go out and start flogging around with your new found power is't probably a good idea it chuck it on the dyno and run it up to see if the AFR's are acceptable in your case. Nissans are generally VERY rich under boost though.
Edited by D_Stirls
I'm not interested in huge power figures and 'flogging' it but just want a little more acceleration. At the moment it hits the factory 5psi by around 3K RPM since the AM split dump and Cat have gone on, just want a gentle extra shove so to speak. I haven't done the hi boost mode mod to the car yet either.
FMIC, full 3" exhaust, I'd put 12psi through a RB25 anyday providing your injectors and fuel pump are in good enough to keep up which unless you have a good ear for pinging even sometimes you can't hear it I would do it all on a dyno so you can watch A/F ratos through out rev range and accurate manifold pressures (boost pressure).
Yeah, i only tuned it to 10.5psi to increase the life of the turbo. 12psi is at peak efficiency for a stock rb25 turbo.
Okay you know how sometimes you see car accidents and you think... how??
Well this afternoon, there was an accident in my suburb, which resulted in a Commodore suffering rear end damage next to a bent power pole. Sounds straightforward huh? But there was a car trailer with a car on it, upside down behind the Commodore - as in right behind - but the Commodore was on 4 wheels. Hope everyone was ok.
Guest
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
