SCOUSERS JOIN FERRARI
"The Ferrari F1 team fired their entire pit crew yesterday."
This announcement followed Ferrari's decision to take advantage of the australian government's 'Work for your Dole' scheme and employ some lonsdale youngsters.
The decision to hire them was brought about by a recent documentary on how unemployed youths from lonsdale were able to remove a set of wheels in less than 6 seconds without proper equipment, whereas Ferrari's existing crew could only do it in 8 seconds with millions of pounds worth of high tech equipment.
It was thought to be an excellent, bold move by the Ferrari management team as most races are won and lost in the pits, giving Ferrari an advantage over every other team.
However, Ferrari got more than they bargained for! At the crew's first practice session, not only was the lonsdale pit crew able to change all four wheels in under 6 seconds but, within 12 seconds, they had re-sprayed, re-badged and sold the car to the Mclaren team for 8 cases of vb, a bag of weed and some photos of Lewis Hamilton's bird in the shower.
We should be so proud of our exports :)
Nope. the car went in to fix up the ratios from lean to normal, but im not sure what they are.
you should always ask for a print out of the air/fuel ratios which they can put on your dyno sheet graph and also ask how much timing its running
thats the mistake i made "not knowing my air/fuel ratios and timing" and 2 months later they leaned my car out on the dyno
bye bye piston 6 ring land after spending ALOT of $$ with them!!!!!!
Valiant update:
Drove it around the block today, and it over heated lol. Pulled the thermostat out and it was siezed up. The pipe was all blocked from corrosion. Cleaned all that out and got it looking nice. Changed the spark plugs and dropped the oil.
Tomorrow i will:
Fill up with coolant and put thermostat in.
Put new engine oil in
Hopefully find someone with a fuel filter instock
And give it a basic check over
Other then all that it will get a wash sometime before sunday.
hey guys...
anyone changed their brake pads (diy) before (specifically 4 piston calipers [33/34gtst])? got any tips for slotting those new pads into the caliper?
those pistons are tough to get past without special tools. Dont want to damage anything! Anyone got any tips?
Just seeing if there's a simple way to install. otherwise i'm going to put the old pads back in and hand it over to my mechanic!
looked at the DIYs but i'm sceptical about some of the methods, and want to avoid damaging anything at all costs
hey guys...
Luke HESLO is the man to speak to, did an awesome job fitting my pads n rotors
i could also add that pete (sled) and luke (lukeenr34) did an admirable job of fitting my front rotors and the 2nd hand pads they found that were infinately better than the ones I had ..
eternally greatful
-D
cheers guys. done a bit more digging in the meantime
gonna take another look. if i think i can compress them properly with the tools i have i'll give it a crack!
otherwise going to put it all back as mentioned
thanks again
what would be the cheapest way to get a car back from vic
drive my mums car and hire a trailer for a couple of days n do an overnight trip?
I had a car freighted over using movingcars.com.au - the actual carrier they used was Patrick Autocare and from memory it was $300 something from Melbourne. It must be able to be driven onto the truck though.
Guest
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
