Dan, that is the poorest excuse ever :).
Does anyone know the exact way to get the dash out so I don't have to remove parts that dont need to be removed, I am changing dash lights and the lights that go where the hazards are etc.
Quick little tip?
Cheers :).
Edited by Weezy
I meant Inline6 Haha.
But your keen, good good. Jenkies Keen, Mad.
3 of us makes for a nice little group.
I am not mad keen on a full on hillzy touge spec my rear tyres have inner wear like a madcunt but I am keen on heading out.
Dash removal - R32 - How :).
cool so chronic wheezy inline6(is a pussey)
wheather is lookin a bit pooey anyone know if its gonna be a clearer night tomorrow. this is starting to look like a 32 gtr fest so possibly try and get as many 32 gtrs together as possible and head out tomorrow night??? get some photos :)
I had actually already planned to meetup with a few other mates aswell for tomorrow night I can't ditch them and be like 'Sorry guys, hanging out with RB26 crew' haha.
If it stays clear tonight Jenkies I don't see why not tonight haha
Dan, that is the poorest excuse ever :) .
Quick little tip?
Cheers :) .
Did this a couple of weeks ago, remove about 4 screws on the top of the drivers side panel under the steering wheel, pull it down ever so gently as to see about another 4 screws under that holding the bottom of the instrument surround in, then 2 screws up the top and 2 screws, one under the headlight switch, one under the wiper switch. Remove the surround (be REALLY careful, 16+ y/o parts can be brittle!) then unplug cables. Instrument cluster is 4 screws and it will pull out + remove plugs behind.
EDIT: Im slack, its probably better to remove the lower panel all together, its an additional 2 screws down the bottom on the left hand side, 1 one the side where the door closes with a little dome cover over the top and 2 screws behind the bonnet release.
Found this aswell: http://www.skylinesaustralia.com/forums/R3...html&hl=r32
Im easy for tonight or tomorrow night aha,
Whatever it may be I dont care.
Either Zillafest as the man says tonight, or all car tomorrow night :).
Almost finished my LED instal haha, my finger tips hurt from trying to get plugs out :).
So much of the dash needs to be pulled apart on a 32, give me a 33 to do anyday ahaha
Nah I found it quite easy. I ended up replacing the entire front section of the interior anyhow (after I'd fitted the led's) so I had to take it apart again, and then had to do it a third time to fix the airconditioner actuator
-D
I went to change my demister globes etc and the socket types are totally different to what I got sent to me from ZeroPoint Electronics?
I don't know, I'll PM him and see how the eff they're meant to work lol.
Anyone cruising tonight or we gonna have a bigger meet tomorrow night?
Take the LED out of the holder he gave you and the globe out of the rubber thing found in the switch. Then cut down the rubber thing (because the LED's wires are shorter) and thread LED wires through, wrap around so the base looks like original but shorter and with an LED. Easy.
Are you doing your climate control? Thats trickier than the switches.
Guest
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
