andrew will like this, domar will probly flame for it but got passed this via a chain email lol:
nah i quite like that one
it was floating around during reagans presidency - one of those jokes that can be modified to suit anyones taste
aka
Q:What do you call 15 blokes sitting around watching the Rugby World Cup on a tv?
A: The wallabies (or whoever the wooden spooner that year is)
-D
need a massive favor..
anyone got a mig welder i can borrow for like 1 day??
I have a gasless mig welder you can borrow. You going to the dinner tonight?
hey guys just wanna say great forum u got here i just wanna put my name out there and hope to meet some of youse in the near future :D
Welcome to SAU. :merli: There's a dinner on tonight (see sig below) .. you can meet more of us there :(
hey ruby, nah im not. its just to weld abit of exhaust up.. prob only need it for like 5mins..
and got me 6x speed flow fittings and hose for only $170 :merli:
cheering
EDIT. might hit up the dinner actually..
Edited by rad32
theres a 1m x 1m pile of horse shit in the middle of grenfell street, and every single car is smushing it into the road, tracking it down grenfell toward king william. town smells like an unkempt farmhouse.
aka
-D
LOL at that wallabies one
from that ped garry?
:merli:
lol
how do i tell which is the inlet and outlet on a oil cooler sandwitch plate and relo kit?
dont wanna get the lines mixed up.
core itself doesnt make any difference.
but with the plate and relo block, they should have little arrows (or simply, "in" and "out") on the ports.
on mine its the outside port on the block adaptor linked to the outside port on the relo block, then the inside port of that feeds the oil cooler core, then the coil cooler feeds the inside port of the block on the engine.
ok on the left is my plate that sits against the block, on the right thr relocation plate.
now u can see the two holes on each which go through to the hoses..
which is in and out?
there are no labels on them at all..
cheering
I'll bring the gear along in case you're there :D
I was on lunch and all i could smell was shit people were looking around at each other like someone had farted it stank
if anyone is keen on a few photos on Sunday, meeting up around 1:00ish, pm me within the next hour for my number. wont be a cruise, just driving to locations for some snaps. i aint no pro either, just getting used to my new SLR.
haha shit
i gotta walk that way to the bus stop after
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
