me and heslo had a brief run in a little later in the night.
well, i did, lol, luke thankfully had the opportunity to bail and took it.
i got let off free though, cop took down all my details, asked a few basic questions, then jetted off to assist another cop at a drunk stop.
as he was getting back in his car he looked over and added in a rather light hearted i-know-exactly-what-youre-doing voice "behave yourselves eh."
Scandy - following on from our conversation at dinner tonight why did you pick that particular chick for your avatar? Don't get me wrong - she's gorgeous and I guess most of the photos from that site wouldn't be approved on SAU, but you've had her smiling at us for a while now. If you can post others... well... post away.
PS - I'm glad that Heslo & yourself avoided the yellow stickers tonight. 1 defect a night should be a limit for SAU-SA.
is this them
Pressure; CS6004W
Temp; CS6003W
not entirely sure eh, the site i was gonna use to reference them is showing 'out of stock' on everything and no longer listing p/n's.
haha, i dunno, i quite like this one, reminds me a lot of an ex. long story. but yeah, might be time for a change of avatar. ill see what i can dig up.
im rather stoked about skipping the canary also. glad it was me that got pulled over instead of luke though, the 200 would be a piece of cake to get through, lukes would be fairly difficult.
Edited by scandyflick
Well I just got defected. Done for cage, suspension, steering wheel. First defect on the car ever. Off to regency I go :D
take it you've got adjustable suspension and a wheel less than 350mm in diameter?
good excuse for you to get that cage engineered
-D
Luke man really sad to hear man, i guess you should be happy with how long you got away with it haha.
I got my headlight out to get some moisture and water out that had gotten into the headlight and it turns out the water has now eated away all the chrome inside the headlight and where the headlight seal had been broken is on the side of impact when they lady kindley reversed into me in traffic having already had the guard replaced and painted by her insurance and a brand new indicator on its way from Japan, I'm going to be putting this headlight back in and taking it to Aami and show them that the evaluater (sp) has missed something and they will be getting it fixed, which is good they said when I first went in if I have any dramas with the repairs etc all repairs are under warrenty. Good oh
Edited by Weezy
Damn, sorry to hear Lukey. But as has been mentioned, you've been so luck to get away with it for so long. :( Be a good opportunity to do that engineering for it now. Would love to see it complete soon :laugh:
And good-o for Craig and Heslo's luck.
Anyone know how much work is involved in removing a r33 rear bar? I've had a look from the bottom but can't clearly see any bolts, I'm guessing that maybe the rear pods, garnish etc comes off and there might be some mount points under all that?
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
