tangles, dont tell me we cant sink a few while doin the actuator!!?!!!!??!???
hehee jks
lol I pm'd you last night with that info, 'cause I was embarressed that I dont have any even after offering it in the actuator thread; was playing on my mind (Im a man of my word)
:D
Im a bad panda, sorry ;)
(unless some1 reads this and pms me, lmao)
I'm bored.
I was looking on that Kansai motorsports website and saw R32 GT-R coilovers.. (2nd hand)
Nissan R32 Gtr coilover kits aftermarket shocks and springs
$550
Nissan R32 GTR KTS coilovers
low kms damper adjustable and base height adjustable
$1,250
Would that stuff fit my GTS-t?
Edited by muirsky
Had a mate come over last night. We stayed up drinking until like 1.00 in the morning!
He's real keen to buy my Stagea. Once he sells his VX ute he'll be throwing some cash my way for a deposit.
:D
Nah, he came over to talk about buying my silver Stagea (not the black one sorry if I fooled yas) and we got into talking about some of the guys we ride with, and then drinking a bit.
But he loooooves the Stag.
:D
:D
do you drive the silver one much ruby?
Gee id love to be you in the morning. "hmm what should i drive today, the black or silver stag? or maybe ill ride one of my bikes.."
Guest
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
