I just hade a spestic moment, i was sitting on my pc chair and the leg snaped and i was left on the ground but i couldnt stop laughing
So now im thinking i got problems :blink:
Ha, Ha....were you doin the big recline thingy?......I've snapped a couple of office chairs in the last 12 months in the same way.....I reckon its because they're cheap junk
lol yap i was all the way back then i was on the floor
so does anyone know why there were like 50 cop cars heading down marion/ south rd today around the airport?
reckon star force were there to. must of been something serious.
they were a day late.... I flew back in friday night. :blink:
BTW, Im with Bigpoond, havn't had a problem with SAU all weekend.
good point
oi, how much shaft play (if any) should my turbo have...............................
Ball bearing..... 5 fifths of f**k all really. Plain journal bearing.... a small amount is acceptable in my eyes...
Got a bit? Where's the play? side to side or lengthways through the turbo? (comp cover to exh. housing)
Hopefully have my new turbo on in a week or two mate. We'll chuck that 25 turbo on ASAP if you think it's a problem.
Edited by R31 drift pig
swapped dump pipes with chris yesterday, mine's still off. had a jiggle (front to rear) with the exhaust wheel and it seems to have a mm or two movement. so lengthways. hasnt been blowin smoke or any shit like that, plus i only gotta run next weekend before i go away to shepparton. See how i go
3 bikies. arrested at the airport. Pathetic really
This is what we get from mike rann, cos hes so uber hardcore tough on bikies n shit...
stupidity
-D
stupidity
-D
These new anti afilliation laws will be interesting as far as enforcing them. I haven't read the fine print yet but I did get pulled over by avatar near Darlington recently to see if & who I was associated with. I'm wondering whether dealing with an outlaw biker through his legitimate bike business for parts etc is allowed? Or whether socializing with clubs that aren't necessarily branded as outlaw clubs like the Long Riders, Vietnam Vets, Ulysses & CMA (Christian Motorcycles Association) will be tolerated?
My mate & I have been invited to one of their clubrooms next Friday night & we're actually contemplating it, moreso out of curiosity.
Guest
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
