i need to get a clutch for my 5speed thats going into the 31 (rb30e clutch)
which 1 and where shoud i get it from ? Read on the 31sky.club at my options and the xtreme HD sounds like the go, being only 25% stiffer over the standard (idem no. KNI24001DHD). How much am i looking at ?
Also do i need a new flywheel or can i use my current 1 thats in with the auto (obviously get it machined)???
thanks
auto uses a flex plate. rb20/25/30 flyhweel all fit.
go to the traders section and ask one of the traders for an rb30e clutch....simple, they'll tell you a proper price.
oh and btw, i wrote the FAQ manual conversion tutorial on the R31 skyline club so any questions dont hesitate.
Edited by Ryanrb25
R34 owners, for your information. This is what happens when you put white L.E.D's in your dash cluster:
But i like it. matches my head unit.
That looks good....but i still prefer the stock white back lights....
Mt Gambier is a beautiful place...
Thanks, found ur post on the 31 club :worship:
:thumbsup:
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
