for face dials like that you just need to take the cluster out, which is a few screwes and then take the clear front cover off and take the needles off and bob's your uncle! well that's how i did mine anyway or you can always take the actual dials out from behind when the cluster is out
Edited by nos man
These have two wires for the accesories to light them up, and change the colours of the dials.
I got myself new boots today. :D
I'll be out wearing them tonight. I'll swing past Kellie's meet tonight with the Brutale.
Don't ask what they cost me :D You don't want to know ... but its far cheaper than ankle surgery!
sorry Jarrad just got home i would think the original dial come off and these go on not 100% sure and im guessing they didnt come with any instructions
the kit i bought was a 300kph speedo for R33 and i had to take the original dials off
as for how to get the dials on you may need to take your needles off and these require a good hard pull too
Thanks man. I might go see someone and get it done properly. Mine are just slip ons, the guy I bought them off said they were just over the top of his original ones.
mine were just put over the original ones!
Yeah I reckon I just need to take the needles out. But its just the wiring part I'm not to crash hot on. I'll ask a mechanic to do a cashie on it.
Guest
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
    • Tomei or Nitto, don't use the OEM one or Cosmetic ☺️
