congrats on the sale of the car flick, does that mean you guys will be repping shepparton in the falcoooon?
on another note ive got a business id like to plug for their awesome service. took my radiator to get pressure tested and flushed today, went to Parkside Radiators (also trade as Edwardstown Radiators) at Melrose Park. The guy tested it then and there, showed me where the 2 leaks were, explained what he would need to do to fix, told me not to be too fussed about a couple of bent fins (from fan contact at some point) as it hasnt damaged it. I told him it wasnt a rush to fix it, and that id pick it up same time next week, but he still offered to fix it tonight and have it ready for pickup tomorrow. The clincher: For the pressure test, re-soldering around the top tank outlet, fixing the leak in one of the tubes, replacing the "tap" (which id broken off ages ago and let it weep a lil bit), and giving it a reverse flush, its costing me a grand total of $70
+1 to them
Parkside Radiators
7 Manfull St Melrose Park
lol ryan
nah, need a proper cat
617 is far better than the current 200cfm item :D
definately know, by changing this, easy 200kw tune
last night had the attessa system working , lol
boosts well, bit soft in first, but second and third pull hard
IMO around 200ish atw is enough for the street, always been my goal.
sleeper wagon, nothing outstanding to look at (bar being a Stagea !), but streeter-eater deap down
:banana:
Guest
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
