any idea how much it changes the track and camber?
i ask cos i recently had an LCA changed and the geometries were suspect when i went for a wheel alignment, and im wondering if i replaced a bent 33 arm that was on the car, with a 32 arm :S
got a fair bit done on the celsior today.
it now has no interior, new alpine speakers have been fitted to the original pioneer boxes in the doors, all the wiring for them has been re routed properly, none of that over through the door cards shit.
stock sub, amp and cd changer have been removed, air purifier has been removed, front doors have been prepsol'd for sound deadening, both new amps have been dummy fitted and yeah... should be done in a week or so. :)
is it possible for a fmic to get F***** over time? well....i suppose painting it chrome, then black dosnt help????
and some of the finns dont really look to flash....
hmmmm, she just doesnt feel the same after yesterday
pfffft^^^ me, never, old owner, ummmmm dirty pig= he never did it either.
maybe you should take it off and clean the inside, you might be suprised how much oil they get in them over time. It stops them cooling properly.
do i just take it out and leave the piping?
what do i clean it with?
Guest
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
    • 100% agree. Best bet on an RB will be NEO, but even it will be a long way off. Emissions is one of the big reasons car manufacturers went to DBW and constantly variable cams. When cruising, open the throttle right up, but reduce dynamic compression so low, that it's basically an unrestricted air pump moving very little air.
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
