The Sa Wasteland
Cubes
 Share
ill prob just grab a litre of degreaser, its nearly cheaper lol
Be very careful with degreaser and aluminium as it has a tendency to react and damage the aluminium.
yeah im thinking i want to do the same
anyone have a R33 stock air box would like to swap for pod filter
PM me will put up in the wanted section later
I believe so! I've got a HKS pod under it. Its only there to appear stock ... so is the rest of the work to the bay. Got to keep it looking stock as a bone :)
I'm also replacing my plugs and ensuring the gap is 0.8mm.
Mmmmm ... coilpacks :D
With coppers. Best/cheapest place to grab them is Motor Traders at around $2.85 per plug. Else where pay the usual $4.40 per plug. Which really isn't that much anyway.
RB20/25/26
BCPR6E for stock power to around 250-300rwkw. 0.8mm pregapped.
BKR7E-11 for powers 250rwkw+. 1.1mm pregapped need to gap down to 0.6-0.8mm depending on boost.
The two above plugs are the v-groove type.
I find they last a good 20,000km's. By 30,000km's they are beginning to look quite rounded. :)
I run the BKR7E's have absolutely no issues with fouling. At 268rwkw the BCPR6E's were coming out a looking a little hot, the BKR7E's heat range is spot on and look nicely tanned.
If you have issues with fouling the car is running way too rich and really should be sorted.
ok i took my coilpack cover off....
started the car waited 20mins or so to hit full operating temp...
nothing...
so i drove it and still NOTHING
so i have come to the conclusion that it may be getting hot under the cover at full opp temp?
i guess i drive it with the cover off till my spitfires arrive.. is it ok to leave the cover off??
and i correct in saying that this was prob the problem?
cheers
no, 120 the set, Simon32 says just get copper there fine you just may need to replace them sooner
iridiums are meant to last longer thats why there dearer oh and there made of iridium i guess
blow me down! i just ripped one out and its ngk irridum.. looks fairly clean and its gapped to 1.0 or something, will close them all down to 0.7 and see how i go.
yeh i got coppers in mine! at $2 or wateva each to change them 2 times to the iridium once i think thats alright! jeff suggested me get the coppers!
i got NGK iridiums for like 10 bucks or less each i think it was
and get a vented coil pack cover like mine :(
i can pm u the number of the guy who makes em if ya want me too.
it is 15 mm bigger then the standard wheel size overall
so bigger rims with literally skinny ass rims is aloud as long as the load rating still is legal
something like that
Guest
 Share
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
    • 25de in c33 a31 is different to r32/r33 s1 which is different to r33 s2 & r34 so you can vaguely do whatever man.
    • That's the pink sticker type, you haven't said what car so no idea if it's correct, 25de or det is the same in the same model.
