im not sure, kinda hard to understand what the old bat babbles on, she said it makes a really bad noise, and runs like shit, not in those words of course.
but as i said, the body/interior looks good condish, good for the $ she wants for sure.
well im off to bed to, im with steve, i need all the beauty sleep i can get! lol
how about a KE70? anyone got one for sale or know someone selling one?
think its time for my car to become a weekend-er
i think there is one in adel for sale! in the general for sale cars thread!!
Sean/Boostworx runs in the improved production with a little 808 I believe it is.
In his old rx7 I believe his best time around mallala was a low 1min 17?
Yeh thats right, He's building his 808 now, Our lap record holder has a 808 also and is a team mate, runs a BP18T 1.8ltr ran a 1:15, our cars are also restricted, has a 36mm restrictor smack bang in front of the turbo, only running about 200kw!!
Q: What should one pay for an SAFC II Tune? picking one up for the legnum, will install it myself and then look to have it tuned. Was thinking of going to see Shaun (boostworx) but as he doesnt have AWD dyno would mean he would have to hire out someone elses and may affect cost.
Either way, I would guess no more than $200 - is this fair?
Guest
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
