Just a Drift Australia update from the weekend for those that dont know the results already :sick:
Toyo Tires Drift Australia Series Eastern Creek Top Eight
1. Leighton Fine (SA, Toyo Tires Nissan 180SX)
2. Luke Fink (VIC, Holford Motors Nissan Silvia)
3. Beau Yates (NSW, Toyota Racing Developments Toyota AE86 Sprinter)
4. Khudar Elhaouli (VIC, JDS Auto Imports Nissan Silvia)
5. Linden Reynolds (SA, WheelWorx Nissan Silvia)
6. Darren Appleton (QLD, Peer Industries Nissan Silvia)
7. Adam May (SA, WheelWorx Nissan Skyline)
8. Adam Trewhella (WA, Miluc Civil Nissan Cefiro)
Toyo Tires Drift Australia Series Standings
1. Leighton Fine (SA, Commercial Truck Sales Nissan 180SX) - 1836
2. Luke Fink (VIC, Holford Motors Nissan Silvia) - 1766
3. Beau Yates (NSW, Toyota Racing Developments Toyota AE86 Sprinter) - 1607
4. Adam May (SA, WheelWorx Nissan Skyline) - 1424
5. Khudar Elhaouli (VIC, JDS Auto Imports Nissan Silvia) - 1401
6. Christian Pickering (SA, Senwill Civil Nissan Silvia) - 1395
7. Robbie Bolger (QLD, VIP Petfoods Holden Monaro) - 1395
8. Tom Monkhouse (SA, Japanese Motorsport Nissan Silvia) - 1382
Guest
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
