bord bord bord bord bord bord dmdesljksxdfz,mnbzds/lfgh bord but........................... i brought some new dior last night yay ................................thats all bord bord "sigh as i bang my head"
Just got the car on the dyno, still need to put gtr injectors in and get jeff to remap. Does any1 know if this is ok??
Looks good.. ~7 years ago mine made 164rwkw on 15psi with 12:1 afr's.
Went damn well 0-100 in low 5secs and 0-180ish in high 13's to flat 14's.
thats great
are you coming on the cruise havent seen you in ages
small bearded dragon
large tree
impressive written assignment
large
legs
farting noises
death
arm wrestle
I wrestled a bear once
small ant
rather cute lady
beer
carlton dry fusion
cutie bubby.
booooooogy boooooooogy bum bum
pretty impressive! got a friend who has an r32 as well with a high flowed turbo! pushed out decent power, like over 190kw or so! but it lagged out like crazy, didn't see any power till almost 5000rpm!
thats great
Unfortunately not; the car is laid up in the drive way. Fitting a set of cams tomorrow; replacing the steering rack after work during the week; then in for a tune so I will miss the cruise.
I had a larger turbo on the rb20det for a while; the following week I dropped the stocker back on and crammed 1bar back in to it as the larger turbo was gutless through first and was slower for general street duties than the highflow. Which is when I decided the rb20det was not for me.
so what you decided to build an rb30? must have pretty crazy torque
huh?? Someone correct me if I'm wrong but that fuel map looks like its all over the place.
I'm assuming the bottom graph is AFR's & not boost pressure & therefore should be alot flatter.....anywhere between 11.5 - 12.2 depending on your preference.
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
