ryan if i had the cash i would buy urs!!
i love it! follwing u home the other night and watching ur exhaust popping ambers on limiter was sexual!
perfect example of a 33!
pm me a price hahaha
While i have a spare minute, amongst all this moving house hassle,
id like to give Ryan (Ryanrb25) i plug!
he did my timing belt, and water pump today,
GREAT JOB! did every thing right the first time, and took his time to ensure the job was done properly!
treated my car as if it where his own!
he even organised the parts for me, i didnt do a thing!
best of all, it was by far cheaper than a mechanic!
if you need anything done, and not sure how to do it yourself, and dont wanna pay an overpriced mechanic,
be sure to drop him a PM!
he's a champ
thanks again ryan, she is running sweet!
:P:D
Ive done this a few times, I did it on my own car, you have to work out latency etc...Ill work it out and get back to you what to change if you want.
Yeah that would be good thanks Ryan :P Im guessing the injectors are easy to fit, so ill try and do them myself, and the Nismo pump.
Just make sure before you do it chad, The plugs on your standard injectors fit the Sard Injectors, May need to change them, but that may just be Side fed's on the rb25. Just make sure just incase, You dont want to rip the rail out and realise they wont fit. I'll try sort out these correction values and let you know.
Has anyone bought items of a store on ebay called Lewis engines performance engines1? they have RB 20/ 25 ARP head stud kits for $265 + $15 postage.
Also What should i be paying for a r33 gts-t OEM thermostat or should i go nismo, iv herd running a nismo thermostat can cause probs with a street car?
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
