how you feeling today Luke,
wanna come on that cruise if you can get a lift to the meeting point you can come in my car still
ah well off to everlast mufflers to fit the other rear turbo brake line and my awd shaft
Still feeling quite under the weather Steve, would love to come but don't think I'd like to risk out being out that long the way that I feel. Thanks for the offer though! Hopefully once all this Regency bullshit is aside, I can FINALLY get my turbos, whack them on and go on an ohhh so sweet cruise with you all :D
what for? you have a handbrake dont you :bunny:
hahaha yes i do!
wouldn't you need R33 callipers too
oh and i have rotors
i dont know wat i need?? i need a full r33 front brake setup yeh?
adrian, When you change your brakes, ill buy your brakes off you for the 31.
keep that in mind!!!
done ryan! there all yours!
Trying to get Adrian's standard struts in but i cant seem to get the front ones in since the hub does not move down any further!! Adrian has already suggested i use spring
compressors to compress the spring --> fit it then loosen it. Would this work and who has one!!!
Cheers
-Min
good cruise!! AGAIN..
had a visit from 6coppers at the last meet point but kel talked her way through it and they were fine! asked a few Q's checked rego.. all sweet...
cruises like this are starting to give SAU a better name with the police!
well done again kel now weres the pics!!
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
