Happy Birthday Carl
Damo you want side feed injectors
Damo has a 34 so he will need top feed high impedence injectors i think. Cant remeber whether they are high or low impedence injectors needed.
Well it depends on how much power your after
there is a calculator that you can put in how much power you want to make and it will tell you what size injectors you will need, it will also tell you what power different inj. Will make
So would i be aiming for 550cc or thereabouts for my setup?
440's are good for ~260rwkw and can be squeezed to around 290-300rwkw with some additional fuel pressure.
550's are usually good for a 'little' over 300rwkw before they require more fuel.
If it were myself... Go a set of large sard twin spray 800's they atomise fuel well and then you have the option to tune on E85 and pull an additional 30rwkw out of it and pay less for fuel. :D
Damo i bought mine from Deatschwerks (spelling) in America great pricing and they have a pretty good rep on here.
I have 550cc yuo can buy them off me if you want for the price i paid for them as i think i might go larger.
Bolt straight in with no issues and they have been flow matched from there factory in the US.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
